HKS GTS8555 Supercharger?
Old 05-22-2016, 01:44 PM
INTIMAZY
INTIMAZY's Avatar
Default HKS GTS8555 Supercharger?
Although the answer nowadays is usually "turbo," I noticed HKS has an interesting part number on their website that I couldn't find much information about.
12001-AN008
Found here:
http://www.hksusa.com/12001-an008-gt...-vq35de-ver-2/
Is this real? Anyone have it? The only references I could find about the HKS GTS8550 or GTS8555 were about ambitious plans to release a kit for our car that never happened. Is this unicorn back from the dead or just a dead link? Looks like you can order it today at a few online retailers.
Old 05-22-2016, 03:27 PM
Conway_160
Conway_160's Avatar
https://my350z.com/forum/product-ann...ts-500whp.html
Old 05-22-2016, 06:48 PM
INTIMAZY
INTIMAZY's Avatar
I don't know how I missed that announcement. Awesome!
Old 05-22-2016, 11:11 PM
Conway_160
Conway_160's Avatar
:-) good luck in your ventures.
Old 07-28-2017, 01:15 AM
INTIMAZY
INTIMAZY's Avatar
Blast from the past!
I pulled the trigger and picked up the newer GTS8555 based kit. Already have a ton of spare injectors from my 2JZ/1JZ projects. Just need to update my Uprev and drop in a bigger fuel pump and should be ok.
I will be running it on a stock block for now. I know HKS states this setup is for built motors but the dyno numbers they provide really only show barely more than 400ft/lbs of torque which is within stock shortblock territory. 110mm pulley. No idea how much boost that provides in PSI. Anyone run one of these blowers yet?
Old 08-01-2017, 11:58 AM
AKS14
AKS14's Avatar
Keep us posted, I am planning on picking one of those kits up in about a month or so, but it will be going on a built motor.
I'm curious to see how other people fair power wise, even on stock bottom ends.
Old 08-01-2017, 06:31 PM
INTIMAZY
INTIMAZY's Avatar
There's so little information out about them I feel like I'm setting myself up for failure. I chose the 110mm pulley to keep boost down but I'm not even sure what PSI i will be working with! I know HKS makes a 120mm pulley as well but it's not shown as an "option" for the GTS8555 nor does it have a recommended belt size.
Old 08-23-2017, 10:47 PM
DarkZ03
DarkZ03's Avatar
A little late but if you look at the graph it shows you the psi.
Old 08-26-2017, 03:33 PM
INTIMAZY
INTIMAZY's Avatar
I don't see it?
Old 08-30-2017, 08:43 PM
onevq35de
onevq35de's Avatar
The red lines clearly represent the 100mm, I think? The blue lines are the old version (1) therefore the green lines are the 110mm? That seems like quite a divergence in hp/tq between 100 & 110mm pulley sizes. Perhaps this is why there's no specific mention of the green. They want you focused on the difference between blue & red! If this is the case, than the V2 is either a very minor bump in power from the V1 (110mm) or a stock drive train time bomb (100mm). Look @ the torque & where it's @ in the rpm range. Looks like a roots type blower. Wish the chart went back to 2k rpm's. No 105mm pulley HKS?
Check out their fuel upgrade kit (14007-AN005). I found it @ one site for just shy of $1,500 which oddly enough was $100 more than the fuel kit for the GTR? WTF? GTR kit comes w/2 195lph pumps & 860cc injectors. Z kit comes w/1 195lph pump & 860cc injectors. 860cc injectors. EIGHT HUNDRED & SIXTY CC INJECTORS & A LITTLE 195 LPH PUMP! WTF?
I gotta say, I'm intrigued. I spoke w/a a well known tuner who had the original V1 & he loved it. Either way, I'd cut the fuel kit cost in 1/2 & go Walbro & DW. I've been researching this s.c. for a week now & am interested as well. Glad I found such a recent post w/others interested. Who's got this motha fukka installed right now?
Old 08-31-2017, 12:51 AM
DarkZ03
DarkZ03's Avatar
They used to show the psi in bar before, I guess they don't anymore...I think it was 1.2bar but don't quote me on that lol.
Old 08-31-2017, 05:07 AM
onevq35de
onevq35de's Avatar
It's putting out right around 500hp & 410 ft lbs on the 100mm @ their respective peaks. The hp line looks like a cent. s.c. but the torque looks like a blower. 1.2 bar is too much for a stock block w/blower-like torque. If I go this route, gonna have to go 110mm till I build. Bummer.
There is a long forum on a BRZ site. Multiple people from HKS chime in from time to time answering questions. Seems when I pulled the #'s for the pulleys, one of'em read "for BRZ". I think it's possible to swap pulleys w/units from other makes. Maybe there's a 105mm after all? Got to buy the pulley & belts SEPARATELY from the s.c.. Here's some links that get you to where you need to go for all those reading this post;
https://www.hks-power.co.jp/en/produ...ch/product/552
Quote from HKS site "FAIRLADY Z UA-, CBA-Z33 VQ35DE 02/07-06/10 GTS8555 12001-AN008
Detail
For MT/AT, Requires purchase of supercharger pulley and belt separately, depending on the target power output. Installation may require Fuel Upgrade Kit(14007-AN005) available separately."
https://www.hks-power.co.jp/en/produ...arger/db/17636
Old 09-04-2017, 02:16 PM
INTIMAZY
INTIMAZY's Avatar
Yea I'm unsure what PSI each pulley is. I went 110mm but I have zero clue what that will make in pressure until I start it up I guess.
I'm going CJM or AAM for fuel. Not sure about the HKS setup but these other ones have been around forever and work well.
onevq35de (09-04-2017)
Old 09-04-2017, 03:02 PM
onevq35de
onevq35de's Avatar
Hey, saw u had 0 thanks. WTF? I hooked u up son!
So how long do u gotta wait for it after u buy it?
My big issue is that it's coming from Japan, which is great, made in Japan but I gotta wait 2-3 months for it so says 2 dealers? What, are they stringing this ****in thing to a flock of birds to get it to the usa? Do they have two guys in a back room somewhere puttin'em together in their spare time or something? Just seems like HKS doesn't give a damn if they sell any or not & then if it brakes, hey staten island, forget about it, right? Another 2-3 months @ least. Don't mean to sound discouraging but this thing has some transportation issues. These BRZ guys were waiting many months to get their **** back after it broke.
Here's a link for anyone interested. These guys probably have the most & the most recent experience. The link is to the last page where yet again, some poor dude's not getting any support from hks;
http://www.ft86club.com/forums/showt...=89226&page=52
Old 09-04-2017, 07:03 PM
INTIMAZY
INTIMAZY's Avatar
I already have mine Took about 3 months to arrive.
I'm expecting minimal support. HKS no longer has a US division as of a few years ago. I'm pretty comfortable with metalwork after dealing with the SC300 and MR2 projects so this should be manageable. I still don't know for certain that this will fit a Revup but time will tell. It will be a winter project for me. I'm finishing my E85 fuel setup and bodywork on the Lexus first before going back to this car.
Thanks for the 'thanks' ! I used to be much more active on here years ago but jumped on the 2JZ/1JZ bandwagon and now have a hard time with working on a car that struggles to make 450hp without blowing up.
Old 09-05-2017, 04:46 AM
onevq35de
onevq35de's Avatar
Yeah, they left but have come back to the usa but still, I guess everything's still coming from Japan. Maybe @ some point they will have some stock here. Glad you got it. Jealous. I'm sure you'll be able to make it fit. Only 450hp? Awh, poor you & your not braking the sound barrier but still ****ing fast car. I pity you sir!
Old 09-05-2017, 07:57 AM
AKS14
AKS14's Avatar
There are at minimum 4 kits in stock in the USA right now for the part number 12001-AN008 with some of their various distributors.
HKS did pull out of the US market a few years back, however they always maintained a relationship with distributors to sell their parts in this market. A new "HKS USA" was formed as sort of a joint venture with their master distributor in the USA, but that has since been dissolved and they have a new HKS USA warehouse in the Southwest of the USA, staffed by a limited HKS staff that opened up earlier this year.
onevq35de (09-05-2017)
Old 09-05-2017, 08:22 AM
onevq35de
onevq35de's Avatar
No kidding? Seems folks in the swamp are better informed than those in the south. You seem very confident in what you say, so my question to u AKS14 is are u willing to pm me regarding who's gott'em & how to contact HKS?
They're very elusive, to the point where I contacted a known distributor on HKS's list & this distributor had to "attempt" to contact HKS via said distributors "Japanese speaking relations guy". They reached out to HKS over a week ago & no reply. That's cold. Talk about playing hard to get.
I know HKS makes quality but they are not indestructible, nobodies perfect & **** does happen, so even if I obtained one, I suppose fingers crossed, hope & prayer would continually be on my conscious which makes me ask myself, am I just looking for trouble?
Just read this thread again & noticed INTIMAZY has/had the same feeling "There's so little information out about them I feel like I'm setting myself up for failure." Yes, gotta have a little faith I suppose &/or big *****.
Old 09-05-2017, 01:00 PM
AKS14
AKS14's Avatar
The kits I checked on are at wholesale business to business distribution warehouses, so they would not be able to sell to you directly as a retail customer.
That being said, any of the authorized HKS distributors in the US should be able to source that for you within a matter of days, and also, from what I recall HKS USA really is there as a dealer informational tool, to support and inform their authorized dealers of new products, discontinued items, etc.
You could try info_usa@hks-power.co.jp but I am not sure how often they check that.
I have a contact direct with HKS and he is generally pretty good at getting back to me within 1-2 business days even if he is in Japan at the time.
If you wanted to get a kit on order PM me and I can check shipping rates to your location and also get whichever pulley kit you wanted set up with it as I am an authorized HKS Master Seller.
Old 09-05-2017, 02:35 PM
onevq35de
onevq35de's Avatar
I figured you were an HKS employee. Guess I was close. Spoke w/several (4-6?) HKS listed distributors & most new little to nothing, was it tremotorsports that didn't even know HKS made a kit for the 350z? Yeah, it was tremototrsports. Nice guy but no info or interest in obtaining said info. Everyone I spoke with needed to order it (2-3 months out). Guess they aren't to interested in doing the work to earn my $ or their homework to learn their products, not that I was at all surprised, unfortunately.
Whatever it is I chose, save for the Procharger, must be modified to fit my FX35. If HKS still made their FX kit or even the G, but in the V2 & I was able to get a few questions answered, then I'd lean a lot closer to HKS but that's not reality. If for whatever reason I change my mind, I will definitely contact you 1st & see where you're at but w/the opportunity to get the ati under $5k & vortech for a bit over $4k, HKS & all the issues I've mentioned in previous posts are a tough sell. & here's a thanks coming your way HKS... I mean "A"KS14.
Quick Reply: HKS GTS8555 Supercharger?
