1000th Vortech build etc. Looking for the bottlenecks
Here's my build thus far:
Vortech V2 Ti Trim
Billet idler pulleys
GTM tensioner
2.87 928 Pulley
34/28 Cogs
Timrod Radius Rod
Fluidampr Damper Crank Pulley
Kinetix SSV (with reinforced welding)
NWP 75mm Throttle Body
Tial Q 50mm BOV (2 psi Spring)
CJM Stage S3 Fuel Return system
CJM Twin fuel Pumps
GM Flexfuel Sensor
Bosch 2200cc Injectors
Aeromotive Inline Fuel Filter (10 micron glass)
OEM Revup Oil pump
3in. MAF Tube
Weisco 11:1 Pistons (95.5 stock spec)
K1 H Beam Rods
ACL Rod/Main bearings
ARP L19 Studs
Cometic Head Gasket
Link G4 Standalone
Treadstone 1245 Intercooler
Motordyne TDX 2 Shockwave w/ XYZ pipe.
OBX Long Tube Headers
WB Wideband
AEM Boost gauge
AEM Oil Temp gauge
Glowshift Fuel Pressure Gauge
Mishimoto Radiator with Mishimoto Fan shroud modified for SPAL fans.
Z1 Master silicon hose set
Nismo Thermostat
Mishimoto Oil cooler
OS Giken Twin Disc Clutch
Vortech V2 Ti Trim
GTM tensioner
2.87 928 Pulley
34/28 Cogs
Timrod Radius Rod
CJM Twin fuel Pumps
GM Flexfuel Sensor
OEM Revup Oil pump
3in. MAF Tube
K1 H Beam Rods
ARP L19 Studs
Cometic Head Gasket
Link G4 Standalone
WB Wideband
AEM Boost gauge
AEM Oil Temp gauge
Nismo Thermostat
To answer Question #2:
-To maximize boost/boost faster, switch to a 28/34 cog setup
-Yes, a Fluidamper will increase boost/boost faster because it has a bigger diameter than the stock crank pulley and spin the blower faster...an ATI will maximize boost/boost faster even more as its has an even bigger diameter than the fluidamper...limiting factor will be potential belt slip on the 2.87 jackshaft, you may want to get the TIMROD to help with that, and a super tight belt....also be watch your impeller speed and don't overspin it too much...
A lot of my turbo friends are giving me enough beef that I'm running high compression but ... Yeah. Another though was running high injectors for sure since I know that I'll be running my limits, but I'm getting what I can before I convert to the YSi. I'm looking around but struggling to find the TIMROD setup. I'll just have to message oldman350z later about it.
I'm always reading up on your builds and have you ran into any other problems with the 2.75 besides the belt slip?
Do you have a mod list? Wondering if you're still using the stock heads. Also what redline you're operating from.
I greatly recommend a standalone; its incredible how much better my tune got and how much more stable it was when I went to Infinity, in particular with the larger injectors/twin pump setup I had to go to with E85; there's only so much uprev can do.
But, no I haven't really had any issues directly related the vortech kit; my latest mod list in my 600whp thread is basically the same, except now I'm running E85, Ysi, ATI crank pulley, 2150cc inj, CJM twin pump, and AEM Infinity.
And in all my build threads, I've always had JWT S7R cams, but I only rev to 7000 rpm, which is stock redline for a revup engine.
I haven't had any issues with belt slip yet (knock on wood), but to be practical I would imagine my setup to reach about low 500s at the moment. Rather upgrading the MAF, I'm currently budgeting my build money to save for a Haltech to remove those headaches and future ones.
If you run into belt slip, I would try a carbinite coating. If I get my car on the road and don't sell it first, I will definitely do this before mounting the vortech bracket to the chassis etc.
http://www.carbiniteracing.com/pulley/pulley.html
I have a question in regards to your choice in compression. Why go with the 11.1 compression instead of a lower compression ratio like 8.1, 9 or even stock 10.1? You are gonna be revving really high with those camshafts and producing alot more boost the higher you rev. Is it safe even with the E85 at this high of a compression?
The reason I am asking for your reason is because I may be buying a 11.1 built shortblock in the future round xmas but will plan on staying on pump gas with a large sized meth spray nozzle, 100% methanol injection kit. Thanks.
BluestreamDE (07-21-2016)
Hopefully that little difference past 60k wont be too crazy on the impeller.
If only I could swap to 2.37 and just wastegate the boost....but that doesn't cancel out the faster impeller speed. *sigh*
All the parts came in for the engine build, except K1 Tech decided to give us VQ37 rods so now the build is on hold again.
How much timing were you running on your "street tune"? Might want to get it properly tuned before boosting it this time... if you want to tune it yourself, a standalone is much easier and safer than UpRev but either is capable.
I spin mine faster than that.
Best way to go is a 34 tooth cog on the back of the Jackshaft.
Bleeding off the Boost is a waste of time and money.
Everything is nearly complete with the rebuild and I just realized something.
I'm not sure what belt size I should go with now that I have the Fluidampr.
I would imagine since the increase isn't too great, that I could just adjust the tension on my current belt, or should I make the switch to the Gates Fleetrunner belt? If so, what size should I run?
The factors include:
VQ35DE
Fluidampr
2.87 pulley
GTM pulley
VQ35DE
Fluidampr
2.87 pulley
GTM pulley
Use a string and map it out. Then you can figure out the size from there. Pick up some cheap belts from autozone to get the size correct. Then when you get the correct size order a gates HD belt. All others are sh*t. Especially when you start spinning that blower hard. Tighten it down till its tight, then tighten some more. When choosing a belt you want the tensionen maxed all the way down and barely able to get the belt on. Then tighten it from there.
