350z ECU Check Engine Light
I have a 2003 350z which was disconnected from its battery for 2 months due to getting body work after a minor accident. The car runs fine and sounds fine, not internal components were affected in the accident only my front bumper and hood. The car has a check engine light and the code comes up with the "ECU" code when i had the code read. (i don't have the actual code because i forgot it; Autozone looked it up in their book and said it was due to my ECU. I have heard of ECU reflashing but didn't want to go through 130$ to find out it has nothing to do with a reflash. I've also tried resetting it via ignition/stepping on a pedal and blah blah. any one have any past experiences to help me?
My friend, no code, no help. Sorry, but we're not telepathic. Take the car to any suto parts store and have it read again, but write it down this time. Better yet, spend $20 and buy yourself a code reader.
https://www.amazon.com/Foseal-Scanne...s=obdii+reader
Logiqal (01-22-2017)
If it's a code related to the ecu and it's been unplugged i bet it's P1065. This commonly happens when the z has been unhooked for a while. You can clear the code and it shouldn't come back.
yeah it was a pl065. i got the car re-read. i ended up dropping it off at Nissan. thank you! hopefully it just needs a code cleared or to be reflashed
UPDATE : i brought the car to Nissan, apparently the code was erased and hasn't returned after I disconnected my battery (the CEL was still on but for a misfire) so i brought it to Nissan for nothing...well a Misfire code ...ugh lol. Code was pl0065 -- ECM Back up.
ECU reset
is it important to drive car after ecu reset ?????as a video shows on youtube tells that drive car after rest as your car start learning things again
