Uprev question
Old 05-13-2017, 08:23 PM
Steelcyclone
Steelcyclone's Avatar
Default Uprev question
Question on UpRev flashing, i'm trying to flash a base map and keep getting "Unable to Flash Vehicle". I'm assuming i'm doing something wrong but the instructions seem pretty straight forward so i'm not sure. The car previously had uprev tuned about 8 months ago, don't know if that makes a difference or not.
These are the instructions I followed
ECU Flashing Instructions:
Verify that all electrical loads are off
(seat heaters, climate control fans, headlights, etc.)
1. Connect cable to USB port
and vehicle OBD-II port
2. Turn key to On position
(DO NOT start engine)
3. Wait for vehicle to connect
(ECU Ready in status bar)
4. Select Flash Tune File to choose an
OsirisROM and begin flashing
5. Follow instructions in progress bar
to complete flashing process
Old 05-14-2017, 08:59 AM
dkmura
dkmura's Avatar
Why not call UpRev and just ask them?
Atreyu'z 350 (05-14-2017)
Old 05-14-2017, 09:29 AM
Atreyu'z 350
Atreyu'z 350's Avatar
Hmmm... You may have to pay for another license, since the license is held in the cable.
Old 05-14-2017, 09:36 AM
Steelcyclone
That's the obvious choice but there closed Saturday and Sunday. Was just wondering if anyone may have known the issue to get a faster response. I will be calling them tomorrow after work.
Old 05-14-2017, 11:25 PM
karletto66
karletto66's Avatar
The message box is telling that you need an UNLICENSED cable and you are using a cable with license on it (so you can also waste a license by the way)....I think that's the problem....May is a bug ?
Old 05-15-2017, 07:40 AM
MatthewBouchard
MatthewBouchard's Avatar
Could be 100% off here... To make this as short as possible.
Tried datalogging yesterday. Laptop crashed. Due to the crash AFR WB1/2 were not showing in Cipher. I Reinstalled the software. The new files were not like the old files I download a while back (couldn't find osiris or cipher). I was unable to find Osiris or Cipher in the folder they should have been in. All I saw was "rom editor"(which is what u clicked). I never used that even when flashing my car. I restored the folder(1 week ago version) and everything was good again.
Maybe they changed something or I wasn't looking in the correct area, but my files also include rom editor just as the new files did. Here is the program I used to flash my ecu and what the folder looks like.
Or as stated above, you currently already have an uprev license installed and your cable has one as well, so you need one w/o a license.
Attached Thumbnails Uprev question-20170515_112553.jpg   Uprev question-20170515_112604.jpg
Old 05-15-2017, 12:36 PM
Steelcyclone
Just got off the phone with UpRev, very very helpful. Dustin walked me through the whole process of pulling my license off of this cable so that I can flash. Then after he will put my license back onto this cable. I guess at that point I can sell this tuner cable.
BigBlue (05-15-2017)
Old 05-15-2017, 03:54 PM
Atreyu'z 350
Nice.
Old 05-15-2017, 08:33 PM
BigBlue
BigBlue's Avatar
You should have UpRev Updater. If you find it (I keep it on my desktop with Cipher and ROM editor) keep it updated before logging/flashing a tune. *One little tip before making Cipher logs, click on "clear learned fueling" and do that. Sounds like you have things rolling.
If you have an extra unlicensed cable it is still worth selling (sold mine for $100) because it can still be used to read and clear codes, plus some other diagnostics. Good luck with your tuning, you'll enjoy having this system and all of the options.
Old 05-15-2017, 11:52 PM
Steelcyclone
Thanks, I will have an extra licensed cable. What happen is if you have a licensed cable you're not able to flash a ecu that already has a uprev license on it, you need a unlicensed cable (at least this is the case with the tuner cable). They pulled the license off my tuner cable and then I was able to flash my base map on my ecu that already had uprev flash from a previous dyno tune. Then once I flashed the base map they put the license they took off back onto the tuner cable so it's now a full licensed cable again.
BigBlue (05-16-2017)
Old 05-16-2017, 11:21 AM
BigBlue
BigBlue's Avatar
Sounds good! Yeah, now that cable is quite valuable if you are looking to sell it. That's good that UpRev worked it out with you.
Old 05-17-2017, 12:15 AM
karletto66
karletto66's Avatar
Anyway is TOTALLY IDIOT software: if you already have used and payed a license the software has simply NOT to use another also if available on cable...WHY create these problems ???
And they only raise cost of Uprev....
Old 05-17-2017, 05:59 AM
seymore4
Professional
seymore4's Avatar
It is an annoying feature, but the reason they changed the software so that you can't flash a tuned ECU with a tuner cable that has another license on it is to make it more difficult for untrained/ unlicensed street tuners to present themselves as professional tuners and tune customer vehicles.
In the past there was quite a bit of drama with "fake" protuners running around trying to hustle and make a buck flashing vehicles and not knowing what they were doing, blowing up motors, causing all kinds of headaches for Uprev, since the customer was under the impression that the "tuner" was a legitimate Uprev protuner and when things went south they called Uprev to complain.
The following 2 users liked this post by seymore4:
BigBlue (05-17-2017), terrasmak (05-17-2017)
Old 05-18-2017, 10:24 PM
karletto66
karletto66's Avatar
I don't understand the motivation : a FAKE tuner can write ECU with a void cable without problem. And so ? Where is the way to "protect" people ? Maybe if the make the software that need match from license in ECU and a specific cable tha can be a real way (also if VERY annoynig), in this way i don't see notthing good in any way.
The problem of fake tuners is everywhere, i see also in Italy a lot of a$$holes.
And a "pro" tuner (official Uprev seller) from UK some years ago make me a map for the Z that was totally wrong, not dangerous but simply wrong !
Old 05-19-2017, 10:19 AM
rich2342
rich2342's Avatar
I have the tuner cable and need to flash back to stock. How do I load my stock rom? I located it and won't upload.
Old 05-19-2017, 10:32 AM
seymore4
Professional
seymore4's Avatar
Update your software. Download the "back to stock rom" for your ECU with the Rom Editor. Click "flash tune file" and select your back to stock rom.
Old 05-19-2017, 10:48 AM
rich2342
rich2342's Avatar
Stupid question, but do I use cipher or rom editor to locate and upload the stock rom? I have the stock rom saved to my laptop but I am wondering also if the naming convention matters. I.e. It's save as RICH Back to stock.
Old 05-19-2017, 10:54 AM
seymore4
Professional
seymore4's Avatar
Old 05-19-2017, 10:55 AM
seymore4
Professional
seymore4's Avatar
That is definitely a stupid question since there is no option to flash the ecu with cipher.
Old 05-19-2017, 10:58 AM
rich2342
rich2342's Avatar
It's settled then..
