One Question!
One Question!
So.. 2008 Nissan 350z with 78k miles.... so...
sometimes my exhaust sounds normal.... Greddy Spectum elite axleback....
ok.....
so every couple of weeks... I hear a different sound coming from the exhaust... it is just slightly more gargled.... I dont hear it 9/out of 10 times... about every 2 weeks for a day I hear a different exhaust note... slightly more raspy if you will... what causes this as i think i have maybe something wrong.. but its so sporatic so not sure....??? any help is greatly appreciated!!
has anyone else experiences this? as there is no loss in power just simply sounds slightly different when increasing rpms....
ok.....
ok.....
ok.....
Could be condensation build-up in the exhaust system. Could be a banana in the tailpipe.
The following 3 users liked this post by zakmartin:
i live in southern california... so humidity is mild... just not sure what is causing this. no clue actually.
i suppose i can take a sound vid out the window when im driving to create the same circumstance as when i hear it alone driving...
then can create the same "hold your phone out the window soundclip" when it actually occurs... it could be days or weeks before it happens again...
its so random... thats why i dont think its a leak at all.
General & Tech Moderator
I would love to get a soundclip... but it is so random that this happens and im normally by myself...
gl!
honestly im thinking its just condensation for whatever reason...
I gotcha'. Yeah, when/if you hear it, try to get a sound clip.. It could just be your ECM pulling/advancing timing or adjusting your A/F ratio in response to temperature, load, fuel octane, or altitude.
Some mufflers have weep holes on them to keep the insides from rusting out. When the car's cold, check along the lower rims of your muffler(s) to see if you can find one. If so, check the hole with a toothpick to see if it's clogged. If it is, you're getting condensation build-up that's going to get spit out of the pipe every once in a while and your muffler will eventually need replacement. If you don't mind the sound, it's not that big a deal unless backpressure becomes an issue. Of course, people in the cars behind you will get to see your tailpipe spit liquid like a pissed-off llama. For some reason, I see Chrysler vehicles doing this all the time.
