Brake locked up
Old 07-17-2017, 08:46 PM
Zclumpy
Zclumpy's Avatar
Default Brake locked up
so my old brake pads were pretty much completely useless and I did a brake pad replacement. Now my front passenger brake is locked up and burning when I drive. Any advice on how to fix this would be greatly appreciated
Old 07-17-2017, 10:08 PM
Sounds like something was not assembled correctly
travlee (07-18-2017)
Old 07-18-2017, 04:31 AM
Received 9,043 Likes on 6,509 Posts
when you compressed the piston, did you crack the bleeder valve or open the master cylinder?
Old 07-18-2017, 04:33 AM
Zclumpy
Zclumpy's Avatar
not during the brake pad change but I did afterwards to try to get some of the pressure out of the caliper
Old 07-18-2017, 05:56 AM
dkmura
dkmura's Avatar
It's just a guess, but the caliper piston likely has no dust seal or O-ring left and OP pushed on one side of the piston rather than using a tool and cocked the brake cylinder in the bore. Another question that only a physical inspection can truly answer. Zclumpy- how many miles are on your Z and have you done many brake jobs like this?
Old 07-18-2017, 06:08 AM
Zclumpy
Zclumpy's Avatar
it's got about 116k on it. I haven't had it long so this is the first brake job I've done on this car but I've done plenty on other cars before and had no problems.
Old 07-18-2017, 06:52 AM
Atreyu'z 350
Atreyu'z 350's Avatar
Year? Brembo, non-Brembo? What and how did you compress the piston?..
Old 07-18-2017, 06:54 AM
Zclumpy
Zclumpy's Avatar
03 non brembo. Used a brake compression tool
Old 07-18-2017, 06:55 AM
back to my original question, did you take the cap off the master, or crack the bleeder valve when you compressed it?
Old 07-18-2017, 06:57 AM
Zclumpy
Zclumpy's Avatar
no. Not until after when I tried to relieve pressure
Old 07-18-2017, 07:01 AM
Atreyu'z 350
OK. I'd say disassemble it again, then reassemble it according to this:
http://www.nicoclub.com/service-manu.../coupe/2003/br
Old 07-18-2017, 07:04 AM
Zclumpy
Zclumpy's Avatar
ok thanks
Old 07-18-2017, 07:05 AM
that is prob your issue then
Old 07-18-2017, 07:06 AM
Zclumpy
Zclumpy's Avatar
Not opening it up?
Old 07-18-2017, 07:09 AM
yes, you added pressure to a sealed system...
Old 07-18-2017, 09:52 AM
Zclumpy
Zclumpy's Avatar
Any idea on how to relieve the pressure
Old 07-18-2017, 10:10 AM
iideadeyeii
iideadeyeii's Avatar
Take is apart and diagnose the problem. You could have diagnosed the problem in the time it took you to post.
Old 07-18-2017, 10:51 AM
Atreyu'z 350
lol Dude! It's too late for that now!
Old 07-18-2017, 11:08 AM
Zclumpy
Zclumpy's Avatar
great. Just replace everything I guess
Old 07-18-2017, 11:35 AM
Atreyu'z 350
No.. Just disassemble them. Look for abnormalities. Then reassemble them according to the FSM(factory service manual). You could've just overlooked something. It happens.
