Haltech harness tps issue.
Hey guys finally got my car put together years after i bought my haltech harness system. Immediately had problems. Stuck injector, tons of codes and no app or tps.
fixed injectors. Pulled the factory ecu and saw that the pin for the app was pushed in and bent. Opened up the ecu and fixed the pin. Reinstalled and checked signal in the ecu manager.
app is registering now. Still no tps however. Fired the car up and while the engine is operating the app reads and the tps does as well. Engine revs up normally.
Is this normal? How am I supposed to calibrate tps? I just manually entered in values for the time being
Are you saying that you are monitoring the TPS signal via the haltech (laptop screen) and it's not registering within the haltech? but the car is operating normally?
You calibrate the TPS in the settings(which you've probably already know)
All being viewed via haltech ecu manager on my laptop. I can't calibrate it really because of this. I just manually entered in the same values as the APP for now. Just trying to nail the issues down only dtc's I'm having isn't anything to do with throttle.
that's what i was thinking as well. But it makes it useless to try and calibrate it in the haltech unless you do it while its running lol. I guess I won't worry about it too much. More importantly need to figure out why I have a p1136 code... good to see you still active by the way RC_dash. Used to pick a lot of jnfo off your posts years back. Just getting back into it
