Is this ball joint damaged?
Old 10-17-2017, 09:47 AM
omega007
omega007's Avatar
Default Is this ball joint damaged?
Hi, does this ball joint on the compresion arm/ banana arm looks damaged?
Old 10-17-2017, 09:50 AM
Received 9,045 Likes on 6,511 Posts
try uploading by clicking on this
omega007 (10-17-2017)
Old 10-17-2017, 09:51 AM
boot is def torn, i would replace
omega007
omega007's Avatar
done, check it now please
omega007
omega007's Avatar
Thanks.
whats are the best affordable aftermarket arms, i believe moog for the price/ quality but i could be wrong. i read dormant have fitment issues and moog is better quality.
Old 10-17-2017, 09:57 AM
just replace the ball joint... they press out
https://www.z1motorsports.com/suspen...nt-p-8187.html
Old 10-17-2017, 09:58 AM
omega007
omega007's Avatar
This is is the banana arm. can't be replaced, the ball joint is upside down on that arm, do you still see it torn looking it like this?
Old 10-17-2017, 10:04 AM
what year is the car?
omega007
omega007's Avatar
2005
Old 10-17-2017, 10:10 AM
part #10 in this pic?
Old 10-17-2017, 10:14 AM
omega007
omega007's Avatar
is part 14 on this one:
Old 10-17-2017, 10:33 AM
if it were me, i would replace with oem, but if you have a budget you could look into the cheaper options
Old 10-17-2017, 12:10 PM
iideadeyeii
iideadeyeii's Avatar
PASSANGER
http://www.ebay.com/itm/Front-Lower-...FZgYaR&vxp=mtr
DRIVERS
http://www.ebay.com/itm/Front-Lower-...BZgYaR&vxp=mtr
Old 10-17-2017, 04:21 PM
guitman32
guitman32's Avatar
If its just torn and noticing no ill effects, you do not need to replace. A mechanic could tell you in about 10 minutes.
Old 10-17-2017, 05:02 PM
omega007
omega007's Avatar
i have a clunking on that side. but i also need a new upper spring insulator, and my lower control arm bushings look like are starting to crack on the sides of the arm in a vertical line.
but i don't want to pay the work 2 or 3 times guessing parts, this car still has some parts that haven't been changed since new.
i bought some new:
- strut mounts
- strut mounts insulator
- Banana arms
- Upper arms
- Lower control arms bushings
- knuckle ball joints, in case they are bad
I have changed not so long the inner and outer tie rods, sway bar links, and my sway bar bushing looks good.
now i just got to wait like 2 weeks to get all and install it
guitman32 (10-17-2017)
Old 10-17-2017, 05:09 PM
Disadvantage of living on an island....was there in march and loved the ocean and beach.
Oh, and the pineapple.......best ever
Old 10-17-2017, 05:14 PM
omega007
omega007's Avatar
Cool.
Yes and worse than the waiting is that i have to pay almost $4 per pound and this parts weight a ton
I wish i lived in Miami instead,
Old 11-01-2017, 11:40 AM
omega007
omega007's Avatar
Hi just to update. I replaced all my front arms, ball ball joints, strut mounts and links. And still had a clicking on the car.
No mechanic i wen't was able to figure it out. But i startet looking videos online and suspected a bottom engine mount support nut from a video i saw.
I went to the car and reach for it and it was so loose i could turn it with a single finger.
I coun't believe the issue i had for a couple of years, but just now recently was getting too frequently was so simple.
But i screwed it good and went for a ride and no more sound. Feels like new.
Feels good to finally have this fixed. And finally knowing what it was.
And my car isn't embarrasing no more on bumps or bad roads.
zakmartin (11-01-2017)
