P0455 Emissions Leak Large
Old 11-20-2017, 05:24 PM
Justin T Lavoie
Justin T Lavoie's Avatar
Default P0455 Emissions Leak Large
Please help another car issue 😤. I just fixed my whole front end suspension after 3 months and 3k. Now I got this issue, I think I know the cause but I don't know the part. When you put in a gas pump into the tank there is a metal part that it pushes into. That same part closes when the pump is removed. What is that part. My gas tank is always open due to this part never shutting. 1. What is it? 2. How to fix it? Thanks again! Justin
Old 11-21-2017, 05:27 AM
Atreyu'z 350
Atreyu'z 350's Avatar
Unfortunately, that part is integrated into the neck itself. I would try replacing the gas cap first. Here's the filler neck: https://www.google.com/search?biw=15....0.bgNcIwWIP3A
Also, check and make sure the green evap valve cap is tightly screwed on. It's located in the engine bay on the passenger side. You'll see it..
Old 11-21-2017, 06:50 AM
Justin T Lavoie
Thank you! I ordered a new gas cap right away. I was trying to avoid it being the filler neck. I will check the evap valve.
Old 11-21-2017, 06:52 AM
Justin T Lavoie
How long do I have till this can mess up my car? Do I have to do this repair right away?!? I just spent 3k on other repairs and would like to wait a bit? Bad idea or is it ok?
Old 11-21-2017, 08:11 AM
Atreyu'z 350
It's a low level emissions related fault. You should be ok for a couple weeks, but I wouldn't sit on it for very long.. How long is a 'bit'?
Old 11-21-2017, 08:14 AM
Atreyu'z 350
..but honestly, a new gas cap will probably do the trick.
