Need help with flashing lights
Old 12-11-2017, 10:38 AM
Verokosky
Verokosky's Avatar
Default Need help with flashing lights
I'm not sure how to use this site, I just signed up for help. I couple days ago I was driving and my rpm gauge just started jumping up and down while driving. The rpms of the car didn't change just the guage and then today I was driving and my heater was on then it cut out and the lights for the dials to change the fan and dial to change the heat from feet to window was flashing on and off.
Old 12-11-2017, 10:45 AM
Received 9,045 Likes on 6,511 Posts
check the ribbon connection behind the waterfall
Old 12-11-2017, 11:32 AM
Verokosky
Verokosky's Avatar
the heater shuts on and off and climate guages flicker then my rpm tack started jumping now my temperature gauge is flickering my hazard lights/ singnal lights flash irregular is this a ground short somewhere ? Is there anyway to post videos?
Old 12-11-2017, 12:10 PM
like i said, check ribbon connector to make sure it is properly seated
Old 12-11-2017, 12:25 PM
mrwrolguy
mrwrolguy's Avatar
Get the FSM and start checking grounds.
Old 12-11-2017, 02:37 PM
zakmartin
zakmartin's Avatar
What Trav said. Sounds like your AC Amp is going haywire (among other things.)
Old 12-11-2017, 03:09 PM
Atreyu'z 350
Atreyu'z 350's Avatar
^ That.. Or your IPDM might have gotten wet inside and now it's affecting your CAN bus. Did the passenger side of your engine bay(in the cubby behind the battery) get drenched with water recently?..
Old 12-14-2017, 08:10 PM
Verokosky
Verokosky's Avatar
I removed the panel and took a look everything seems fine back there all the other things happening seem to point to the a.c. amp is there a way to know if it's faulty when all looks okay
Old 12-14-2017, 09:38 PM
Cheese203231
Cheese203231's Avatar
They are plastic parts so at a first glance it may look ok but try disconnecting and reconnecting. As for testing the A/C amp you cannot really do that really a hit or miss.
Old 12-15-2017, 08:34 AM
zakmartin
zakmartin's Avatar
I'll check my car computer this weekend to see if you can perform any bidirectional tests to check the integrity of the system.
ot_bg_sam
04-14-2011 04:43 PM
FairLadyz916
03-31-2009 10:11 AM
Quick Reply: Need help with flashing lights
