Exhaust setup help
Old 12-27-2017, 04:41 PM
Hypes
Hypes's Avatar
Default Exhaust setup help
Everything I could have thought of has been answered thanks everyone!
Old 12-27-2017, 06:22 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
they will all match up, the 2 1/4 inch cat pipes into 2 1/2 inch y pipe pipes isn't going to make a huge difference.
Old 12-27-2017, 07:24 PM
bealljk
bealljk's Avatar
none of it'll make a difference unless you get a retune ...
with that being said everything will work if it was designed for this car. Keeping the cats will help tone-down the rasp but anything without a bonafide muffler is going to be raspy...
go on youtube for sound clips before you pull the trigger on anything -
Old 12-28-2017, 03:59 PM
Hypes
Hypes's Avatar
thank you
Edit: if I used test pipes instead of cats and just swapped them back when inspection time came around would I need a retune every time?
Old 12-28-2017, 07:52 PM
bealljk
bealljk's Avatar
^you'd probably be ok running your non-cat tune when you go in for inspection if you have a tuning solution that uses closed loop fuel control...ie haltech...
Old 12-29-2017, 10:14 PM
Hypes
Hypes's Avatar
i was looking into getting a uprev tune as I have read some good reviews I just don’t want to go down the route of using test pipes than switching back to cats for inspection and than retuning to put back on test pipes
Old 12-30-2017, 05:05 AM
BluestreamDE
BluestreamDE's Avatar
You will be fine. There are ppl right now with full Boltons as we speak and have no tune. You are just swapping the cats for inspection. Drive normally with the stock cats and swap back to test pipes.
Old 12-30-2017, 07:41 AM
Hypes
Hypes's Avatar
my only concern is if I do get test pipes and get a uprev tune and switch back to cats for the inspection than throw the tests back on after would it have to be returned because of the swap
Old 12-30-2017, 08:03 AM
BluestreamDE
I already answered your question. And no you don't need to retune.
Old 12-31-2017, 01:26 AM
CK_32
CK_32's Avatar
Bolt n go.
You can tune if you want like an extra 10hp... But most of that is with the tune aka adding timing, not the exhaust. Exhaust is mostly for sound. The 2-3 HP you gain should be an after thought.
But no you do not need a tune.
Old 01-18-2018, 09:48 AM
Hypes
Hypes's Avatar
Originally Posted by CK_32
Bolt n go.
I would like to thank everyone for sharing information with me, I’m starting to understand everything now but I have one remaining question that’s been sorta answered. The tune as you said adds timing etc and just clears the code for the test pipes. If I have the tune on and take my test pipes off than put on cats than put the test pipes back on afterwards will that tune be unaffected (as if nothing ever was changed, check engine light will not come back on after the test pipes were reintroduced)? Hopefully that makes senseEdit: another way of the question that might make it more easy to understand is say I have a tune than I purchase a new part will that new part be at it’s full potential because of the pre existing tune or if adding a new part would it have to be retuned.
Old 01-18-2018, 09:49 AM
they are usually turned off.... so no, they wont come back
Old 01-18-2018, 09:54 AM
Hypes
Hypes's Avatar
so the tune itself will make it to where any test pipe than comes into the car will be at full potentional and no codes reguardless of how many times I swap it after getting the tune
Old 01-18-2018, 10:08 AM
the tune does not change, swapping test pipes with other test pipes in theory shouldnt change anything.... now say you add headers, plenum spacer, etc... you would need to retune to get the benefit of those
Old 01-19-2018, 05:42 PM
Hypes
Hypes's Avatar
understood thank you.
Colombo
04-21-2012 01:53 PM
jibolean
06-27-2008 11:37 AM
nooooorb
11-24-2006 05:40 AM
orhanz33
08-15-2004 08:40 AM
Quick Reply: Exhaust setup help
