350z Misfire! Nothings working.
Old 01-11-2018, 04:51 PM
350zRomano
350zRomano's Avatar
Angry 350z Misfire! Nothings working.
I have a 350z 6MT and it is currently throwing a P0300 (Random/Multiple Misfire). I did many things and I cant seem to find the problem. It was recently engine swapped because the old one spun a bearing at 140k. I swapped a G35 ( VQ35DE ) engine in and it was missing. I changed the plugs, the coilpacks, crankshaft position sensor, camshaft position sensor ( driver and passenger side ), changed fuel rail and injectors, changed ignition coil sub harness. I have no idea what to do. Any advice?
Old 01-11-2018, 05:46 PM
CK_32
CK_32's Avatar
Are your injectors leaking?
Are the plugs properly tapped?
Was everything installed correctly?
Was the motor damaged before you got it?
Have you been racing it?
Are there mods on the car?
Have you done a vaccume leak test?
350zRomano (01-18-2018)
Old 01-11-2018, 06:30 PM
350zRomano
350zRomano's Avatar
No injectors are good, yes plugs are good, everything was installed correctly, no motor wasnt damaged and did a compression test it was all good aswell. And yes did a vacuum leak test. Im thinking maybe a wiring issue im hoping not
Old 01-13-2018, 09:47 AM
bealljk
bealljk's Avatar
are you 10,000% sure you didnt swap coil plug #6 and #4? They are inherently/logically backwards?
Take a picture of your driver side bank and post it.
The following 2 users liked this post by bealljk:
350zRomano (01-18-2018), Cux350z (01-13-2018)
Old 01-13-2018, 02:53 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
this 99% of the time. Nissan makes it too easy!
Old 01-13-2018, 11:20 PM
bealljk
bealljk's Avatar
I know I'm bat-**** crazy ...
350zRomano (01-17-2018), BluestreamDE (01-14-2018)
Old 01-14-2018, 10:36 AM
Yeah, hate to agree with you but I do..... you're the only person I know that owns a V9 Nissan engine. (Or maybe it's a V10 and I just can't see the label on the opposite side.)
Old 01-15-2018, 05:18 PM
350zRomano
350zRomano's Avatar
Red face
thank you my man i appreciate that picture but im almost sure i have them correctly plugged but i will check. Im starting to think its going to come down to a grounding issue.
Old 01-16-2018, 01:23 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
coil packs ground with two ring terminals on the front timing cover.
Old 01-17-2018, 01:05 PM
350zRomano
350zRomano's Avatar
Unhappy
thanks for all advice. I have not yet got to work on my car due to snowy freezing weather which is effecting me because i also have a fan issue so its hard to ru up the car because it is too loud and too cold. I would appreciate if you guys have more details on grounding wires. The FSM doesnt give too much about them and it is kind of difficult to find them all especially the ones related to my issue.
Old 01-17-2018, 01:22 PM
zakmartin
zakmartin's Avatar
I don't know what you're talking about. Section PG of the FSM has all the info on ground points you could ever need.
Old 01-17-2018, 01:25 PM
350zRomano
350zRomano's Avatar
It most definitely does not. It shows you all the engine ground wires. The other section of all ground wires just lists " top right of dash" etc.
Old 01-17-2018, 05:26 PM
zakmartin
zakmartin's Avatar
Okay, so SPECIFICALLY, which grounding points are you trying to find, assuming you can't get your hands on a wiring diagram?
Old 01-18-2018, 09:04 AM
350zRomano
350zRomano's Avatar
Smile Solved !
Hey fellas, i worked on her yesterday and the first thing i checked was the plugs ( #4 and #6 ) and of course they were swapped!! So angry at myself for not doing this first and not checking this before i did all those other things but atrleast now I know my car is in fantastic shape. It has stopped throwing the code and it is running like a beauty. Thank you for all your advice !!! Drift safe my fellow Z members
Old 01-18-2018, 09:22 AM
bealljk
bealljk's Avatar
you're welcome...so it had nothing to do with a grounding issue?
go and label all your coils/plugs/wires/etc so you NEVER make this mistake again ...
Old 01-18-2018, 09:32 AM
350zRomano
350zRomano's Avatar
Smile
Nope issue was from pure stupidity lol! Thanks again man picture really helped out 💪🏼
Old 01-18-2018, 07:31 PM
CK_32
CK_32's Avatar
Don't feel too bad. I push started my Z for 2 days after I put my turbo kit in.
The starter plug I swore I plugged back in was un plugged when I rechecked it. It happens man lol
LowZ33
05-08-2020 03:45 PM
GarniZ33
12-15-2014 09:31 PM
Black350z9972
01-25-2014 07:36 PM
FairLadyz916
07-21-2010 04:44 PM
claudio.maras
Tuning
03-13-2010 02:34 PM
Quick Reply: 350z Misfire! Nothings working.
