Oil Pressure Sensor Relocation?
Hey. I cracked my oil pressure sensor and am having the stock location welded shut.
I've seen people add oil temp sensors to the lower oil pan and oil coolers, wasn't sure if these areas could be used to relocate the pressure sensor.
Thoughts?
UPDATE:
You can't weld it shut, don't even try.
SOLVED: (see attached)
When I installed the new pan, i didn't notice that there's a bung that must be transferred from your old pan to the new one. See the red circle.
When I cranked the motor over, oil exploded out of that hole with the force of a thousand suns.
Would be a good place to add a sensor.
Thoughts?
UPDATE:
Putting the pressure sensor T in the oil cooler lines might work. If you put a oil pressure sensor on the lower oil pan you will be measuring crankcase pressure not oil pressure.
Alot of the times when people crack the pan from the sensor location, it cracks in multiple places. I actually had a 1/4" male BSP to 1/8" female BSP in hopes of just tapping it, but before the guy started welding he had noticed there were a few additional cracks (perpendicular to the oil pressure sensor location) So for a better chance of probability, he suggested we just coat the pan like it's an east coast winter.
Haha true true. Back then I was a young niave owner. These days I've got a bit more experience under my belt.
The pan is cracked, it's unfixable and can only be replaced. Gonna go pick one up today and do it this weekend
Be careful man. also be sure to prep the sealing surfaces and ensure no oil will seep down once you apply the RTV.
I would dread that job. Godspeed
I found a place to add a new pressure sensor. Please see the first post.
AT1222
05-19-2013 05:47 PM
sentry65
05-20-2005 11:15 AM
