DE vs Revup Differences For TT
Hi,
I've got a 2003 DE car that I'm going to be making my own twin turbo setup for soon, but I also have a 2006 Revup car with no gearbox (don't ask). So I was thinking I could use the revup as kind of a template car to build the turbo manifolds and figure out intercooler pipe routing etc on so that I don't have to take anything apart on the car I'm actually driving fairly often. Then once I've made everything fit on the revup, I can basically just move it over to the DE and have a lot less down time.
So just wondering if anyone can think of any differences on the revup engine (or in the engine bay in general) that would affect the design of the turbo exhaust manifolds or intake pipe routing? I know the revup has variable valve timing on exhaust side but presumably the exhaust ports going to the manifold are still the same?
Cheers
Chris
Cheers
Chris
Welcome to the forum -
Interesting question - the blocks are the same but the heads are different. If I were in your shoes I'd mock/tack everything up on the Rev-up and dry-fit it on the DE before you finalize your welding.
As far as your IC goes - do that after everything is installed on the car. I've done some minor IC pipe work and it seems that having the exact setup would be the most efficient.
It's crossed my mind to fabricate tube headers for the greddy tt kit as the cast iron headers are prone to cracking - it's only a matter of time.
Start a build thread for your progress!
Are you in the UK?
Are you in the UK?
Heads are identical except for the extra sensor on the backside of the revup head. The main difference will be the slight different in the front timing cover
ChrisDe (01-18-2018)
Rev up has tons of space in the back firewall compared to the DE.
My friend had a rev up and it had all sorts of space to reach back there. My DE has very little. I'm sure there is more differences but that's the only one I know for a fact off the top of my head. Both were stock st the time.
Chain cover was also slightly different than mine as well.
Yeah I'm in the UK. As for a build thread, I've documented most stuff I've done to the car in videos on my youtube channel here: https://www.youtube.com/playlist?lis...9bBb-BhwTlS_yh
So kinda seems pointless writing it all out as well, but I'll try get round to writing up some stuff for the twin turbo setup just in case it helps save anyone else all the hours I've had to spend searching for fittings etc and figuring out all the parts we're going to need.
One diff is the cam selection between the two. When I did my build almost 10 years ago, BC2's were all the rage. RevUp had only Kelford or JWT.
From what I rem.....the shop did not mention any benefits of the RevUp........fuel delivery, turbos, exhaust, etc AND MANUAL TRANNY are more important. (Built autos have been problematic for some)
I wasn't planning to do cams tbh, just rods and pistons with lower CR
A few things I did to help my situation ... (maybe there is something you can use from my setup?)
Initially I had my headers wrapped - I've since removed the heat wrap as I feel inherent inconsistencies in the wrap-job will create hot spots and heat stress that'll encourage cracking
I vented my front hood to reduce engine bay temps (if you care, review my greddy twin build page) and it helped quite a bit.
I put two sections of flex hose in system - a set in each test pipe and one in the mid-pipe. Give everything plenty of room to expand & contract
ChrisDe (01-19-2018)
It's no coincidence that it's always the passenger side that cracks in my opinion. The motor torques that way without solid mounts. If anyone has heard of a drivers side cracking let me know.
FYI - finally got round to starting this project a few weeks ago. Made a build thread here if anyone's interested: https://my350z.com/forum/media-share...urbo-350z.html
marcelz
11-21-2006 01:10 PM
