2005 ROADSTER clutch in 2003 coupe
Can i put a 2005 ROADSTER clutch and fly wheel in a 2003 350z coupe??
dose any one know. or should i send the clutch back and get a correct one??
Thanks guys
Thanks guys
I think the only difference for those years is the clutch fork pivot ball. Otherwise you're good to go. If you have a 2003, I highly recommend installing a beefier chromoly pivot ball, I recall that the 2003 pivot ***** were prone to failure due to their longer length and possibly under-engineered steel. In later years (2004+) the length was reduced to resolve the issue.
You can find chromoly replacements from all the major performance parts websites.
Good Luck and Have fun!
-Icer
-Icer
-Icer
-Icer
Another thing that changed in in 2004-5 ish, was the clutch fork. The older long pivot ***** mated with a weaker stamped steel fork. This was later upgraded to a stronger cast part which mates with the shorter pivot ball.
Found out the hard way, when I was doing my clutch...had the car on the stands for two weeks waiting for parts. As I decided to upgrade the fork after finding out.
That said, if all your replacing is the clutch you are good, make sure to replace the throw-out as well though. And if you have the long pivot ball, I would upgrade to a chromoly one just in case or go for the short pivot ball/upgraded fork combo....might as well if you have the trans off.
