Where's the turn signal/emergency flasher?
Old 03-23-2018, 05:00 AM
Harleyduo
Harleyduo's Avatar
Default Where's the turn signal/emergency flasher?
My emergency flashers are not working so I began wondering if that system uses a different flasher mechanism than the turn signals,but then I cannot even find a flasher device at all. Can anybody tell me where that is located? And does anybody know if both the turn signals and the emergency/hazard lights use the same flashing device?
Old 03-23-2018, 05:38 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,055 Likes on 745 Posts
I believe the flasher output goes through the BCM (Body Control Module). There isn't a removable flasher relay like other vehicles.
As for the BCM location, it's next to the fuse block on the driver side in the footwell.
Old 03-23-2018, 05:47 AM
Harleyduo
Harleyduo's Avatar
No wonder I couldn't locate it. That helps a great deal. Do you know if both the turn signals and emergency flashing operate from the same BCM or could they be on different circuits?
Old 03-23-2018, 06:01 AM
Heel Til I Die
Same BCM. I thinks there's only one.
It sounds like you have a few electrical issues with the new vert. Here's a helpful link that should help you troubleshoot your lighting issues. Good luck!
Old 03-23-2018, 06:22 AM
CK_32
CK_32's Avatar
Why did you make a second thread for this in the same section.
Old 01-22-2019, 10:13 AM
rey rey_10
rey rey_10's Avatar
I have a strange issue related to this. My exterior lights work fine but I'm not getting any signals to my cluster.
Harleyduo
03-27-2018 08:41 AM
leykias
07-25-2008 12:25 PM
sintaxeror
06-11-2008 11:47 AM
whitetrack
07-31-2003 02:52 PM
Quick Reply: Where's the turn signal/emergency flasher?
