IAT Temps
Old 05-22-2018, 07:51 AM
wizard
wizard's Avatar
Default IAT Temps
Hi All,
Any tuning guru's on here give some guidance on IAT temps, esp those with the vortech?
Concerned my charge cooler may be too small.
Old 05-22-2018, 04:19 PM
vegasanthony
vegasanthony's Avatar
Get the biggest charge cooler you can fit..removing the crash bar will facilitate this
vortech intercooler is way too small
Old 05-23-2018, 06:01 AM
wizard
wizard's Avatar
That's what I gathered but is there an intercooler you can get which allows one to retain the factory crash bar?
Old 05-23-2018, 06:33 AM
BluestreamDE
BluestreamDE's Avatar
I have the TR1245. Oldman and others praise it as the best in cooling efficiency of the in coming charge intake air. It really is a good intercooler.
I bought mine used with the intercooler welded in the middle of the crash bar.
Old 05-23-2018, 07:43 AM
wizard
wizard's Avatar
What do you mean by in the middle of the crash bar? - Is it difficult the crash bar do you think?
Old 05-23-2018, 08:11 AM
wizard
wizard's Avatar
What do you guys think of the Treadstone vertcal fin intercoolers?
http://www.treadstoneperformance.com...cooler++1000HP
speaking with treadstone they say that the verticals are better for track and more compact also (so easier to mount)?
Old 05-23-2018, 08:14 AM
BluestreamDE
Here is an example of mine. Mind you, I did not cut and weld it together myself, was done by the previous owner.
But to fit your needs for keeping the OEM crash bar and perhaps this intercooler, this is an option.
wizard (05-23-2018)
Old 05-23-2018, 08:23 AM
vegasanthony
Simply No
Take some crazy fabrication to make that fit
Old 05-23-2018, 08:40 AM
wizard
wizard's Avatar
What's the issue with mounting the treadstone TR1245 with the OEM crashbar? is it the thickness, i.e. depth of the TR1245?
I found this one which could do the trick and has the same dimensions but is 1 inch thinner then the TR1245, here: http://www.treadstoneperformance.com...rcooler++760HP
This should be easier to mount with the oem crashbar and should be an improvement over the Vortech charge cooler (8N101-350). Here are the dimensions of all three intercoolers:
1. Vortech intercooler (8N101-350):
20"(W) x 7.8"(H) x 3.5"(D)
2. Treadstone 760hp intercoler (TR1235):
22"(W) x 12.5"(H) x 3.5"(D)
3. Treadstone 100hp intercooler (TR1245):
22"(W) x 12.5"(H) x 4.5"(D)
Opinions appreciated please guys - thanks.
Old 05-25-2018, 01:45 PM
vegasanthony
The issue is that any other cooler doesn't fit
I think your question has been answered get the biggest intercooler you can get rid of the crash bar
BluestreamDE (05-25-2018)
Old 05-28-2018, 11:22 AM
wizard
wizard's Avatar
Thanks - i bought the TR1235. Sure I will have fun mounting it.
I've been logging IAT temps with the stock vortech IC on a 'hot day' (25c+) and have recorded some data which may be of interest to people in the same boat.
I've been told that intake temps should be kept below 120degrees F. I'm in the UK and we do mainly Degrees C. Mostly I am below that but you can see when I creep above it at sustained high RPM and speed. See attached - can only imagine what would happen on track.
Will record some data once the new IC has been mounted. Thanks for all of the input so far.
350 Rookie
09-15-2008 07:55 AM
Mazinger Z
11-20-2007 06:09 PM
athenG
11-20-2007 05:34 PM
gabez33
04-01-2006 07:05 PM
aalzuhair
09-09-2004 11:58 AM
Quick Reply: IAT Temps
