Part came out underneath while driving- my exhaust got loud - what is it???
Old 05-25-2018, 01:05 PM
RazzleDazzle
RazzleDazzle's Avatar
Default Part came out underneath while driving- my exhaust got loud - what is it???
It came out from the front -under the motor bay area of a 2008 350z grand touring manual, nav, with Nismo upgrades
Old 05-25-2018, 02:10 PM
SpartaEvolution
SpartaEvolution's Avatar
It's an o2 sensor non-fouler, used to space the o2 sensor out from the housing to prevent it throwing a code. I ran these when my cats went bad until i could upgrade to ART pipes (which have non-foulers built in). Unfortunately it kinda looks like the weld for the o2 bung broke off, so you'll need to have a new bung welded on, or get new cats/test pipes.
EDIT:
Here is a similar part on Amazon Here is a similar part on Amazon
Old 05-25-2018, 03:24 PM
RazzleDazzle
THANKS for the help!
This is my 4th Z but I’ve never had this happen before -
incant weld so so I guess it’s going to the shop - hoping it’ll be an easy weld? They won’t habe to pull the engine or anything to do it I hope???
also- I have the Nismo intake and full Nismo exhaust on this car - the O2 sensor was always throwing codes - think this will solve the problem or is there anything else I should get or do “while I’m in there”?
Old 05-25-2018, 03:30 PM
SpartaEvolution
It depends on what it came off (cats or test pipe), but they can probably weld it back on while it's still installed on the car. If not, getting the upper bolts for the catalytic converter is a bit of a pain, but the whole thing shouldn't take a shop more than an hour or two.
It depends on what code it was throwing.I don't remember the exact numbers, but if it's the code saying the cat is bad, then the non-fouler should take care of it. If it's the code that says the o2 sensor is bad ('low voltage' is in the code description) then it is likely a bad o2 sensor, which will need to be replaced. Your shop should be able to scan the codes and let you know, at most you're looking at $100 for a new set of sensors, and whatever the labor is to do the welding.
Old 05-25-2018, 03:33 PM
RazzleDazzle
You da man ...
Old 05-25-2018, 03:55 PM
RazzleDazzle
Was just thinking ... since you are da man ...
got a recommendation on the replacement O2 sensor? Place you like to buy from? Brand? Type?
Old 05-25-2018, 04:02 PM
SpartaEvolution
TBH I haven't had an o2 sensor go bad since my first little daily Civic back in college, and I think I just ran with the CEL on after that haha. I'd recommend Bosch just because they are a very reputable brand, but I believe they command a pretty high price as well. If you're planning on reinstalling a set of non-foulers, you probably can't go wrong with any of the brands since they won't be directly in the stream of exhaust. Good luck!
Old 05-25-2018, 08:05 PM
vegasanthony
vegasanthony's Avatar
it's called a welding fail
dyno
03-26-2008 06:01 PM
Nismo 350z
09-29-2006 02:07 PM
Gman2004
03-29-2006 06:51 PM
boma
05-19-2004 06:39 AM
Quick Reply: Part came out underneath while driving- my exhaust got loud - what is it???
