Stuck Caliper or bad axle?
The car will go into gear and rock back and forth but other than that won't budge. basically it feels like someone put a brick/chalk/stopper behind my back wheel and i can't go forward or reverse. The car goes into gear fine forward and reverse. I gave it some serious gas but didn't want to break anything. I have the akebono upgrade caliper and rotors. The car has been sitting for 2 weeks.
Is it a stuck caliper? I would believe I would be able to move but with strong resistance if it was a seized caliper right? Parking brakes were engaged for 2 weeks with no driving. Could it be something with the axle since there is a ton of resistance?
Remove calipers, you will figure it out quickly
If the caliper is stuck, you'll be able to feel a noticeable difference in heat around the wheel of the stuck caliper vs the other 3 after a moderately long drive (~10 minutes on the freeway).
Maybe the pads seized / rusted to the rotors? I know if my rotors get wet (like after washing the wheels) and sit for a few days they will get slightly stuck due to surface rust.
I'd jack the car up, remove the wheels and brake pads. At that point you can check for a stuck caliper.
terrasmak (06-05-2018)
GNZ67
03-24-2016 07:49 PM
