How Screwed am I?
Old 06-17-2018, 06:04 PM
Bernardo Z33
Bernardo Z33's Avatar
Default How Screwed am I?
Hey guys I got new wheels and for some reason I was stupid and tightened my lugs to 95ftlbs. I drove like that for a week. How much damage did it cause? Has anyone on here torque their lugs to that or anything above that and drove without a problem? I think it's 5 to 10ftlbs more than the manual recommends. Thank you all.
Old 06-17-2018, 07:26 PM
onevq35de
onevq35de's Avatar
Damn, you dun did it, didn't you. I don't think you'll be able to recover from this incident. Yep, you're screwed.
Old 06-17-2018, 07:34 PM
jv350z
jv350z's Avatar
very
Old 06-17-2018, 07:39 PM
Bernardo Z33
alright ik you're busting my chops now lol. I apologize I'm new to aftermarket wheels and torque
Bernardo Z33
Originally Posted by jv350z
very
apologies for sounding like a idiot
Old 06-17-2018, 07:45 PM
onevq35de
onevq35de's Avatar
Don't apologize You don't sound like an idiot, just someone in a panic and we're in the mood to pounce.
Remove one lug. If it comes off without stripping, torque it to 80 ft lbs and move on to the next.
Old 06-17-2018, 07:49 PM
Bernardo Z33
Thank you I will surely do that. So from your answer 10ftlbs wouldn't be enough to damage anything would it?
Old 06-18-2018, 04:05 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,061 Likes on 749 Posts
It shouldn't be an issue assuming you're using correct lug nuts. I bet a lot of wheel/tire shops over-torque lug nuts with their air tools and don't bother using a torque wrench to torque it to spec.
Old 06-18-2018, 04:09 AM
dkmura
dkmura's Avatar
Over-torqueing wheels can become a problem if the brakes get used hard. This generates a lot of heat and can warp rotors. Outside this, there's little chance you'll damage the threads or lug seats. I use 85 lb/ft of torque for both street and race applications.
jhc (06-18-2018)
Old 06-18-2018, 04:17 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
I always put mine to 90 ft lbs... Everyone else's get put on as tight as the impact will go then checked with a 22 inch breaker bar to make sure I can't budge it.
Think you will be o.k.
Old 06-18-2018, 06:08 AM
Bernardo Z33
I read about that too. But I don't think 10ft lbs extra would cause this would it? Considering how the previous answer said shops over torque them with an impact.
Old 06-18-2018, 06:09 AM
Bernardo Z33
nice you use 90ft lbs. I guess in my case 5ft lbs more than you won't cause a problem haha
Old 06-18-2018, 07:58 AM
SpartaEvolution
SpartaEvolution's Avatar
Fun Fact: Ford F150 lug nut torque is 150 ft-lbs.
Granted, the F150 uses M14 bolts/studs vs our M12, but the moral of the story is: The wheels can take it.
Old 06-18-2018, 08:35 AM
Bernardo Z33
thanks Sparta! My only other worry is the brake rotors won't warp will they with the 10ftlbs extra?
Old 06-18-2018, 08:47 AM
SpartaEvolution
You need to put some serious heat into the brakes to warp them due to over-torquing. You should be fine.
Old 06-18-2018, 08:53 AM
JMII
JMII's Avatar
Thumbs up
Same here. I track my car and thus beat the crap out of brake pads, calipers, rotors and experienced no warping after 3 sets of rotors.
I have had local tire shop use an impact gun that I know was way over 100lbs but I also go back and re-torque them properly.
Old 06-18-2018, 09:34 AM
Bernardo Z33
very much appreciated friend. It's just daily driven so you're right I don't think anything will happen
Old 06-18-2018, 09:35 AM
Bernardo Z33
alright nice thanks for the feedback friend!
Old 06-18-2018, 06:24 PM
Bak3rme
Bak3rme's Avatar
i Sh*t you not some of these tire mounting places I've seen will take an impact and go to MF TOWN on these lugs. mid 100 ft/lbs range i'd guess.
wadd3456
04-22-2003 07:53 AM
slay2k
12-22-2002 09:40 AM
MikeyDNY
10-10-2002 01:23 PM
Robert333
10-08-2002 08:34 PM
drivebywire
08-08-2002 06:08 AM
Quick Reply: How Screwed am I?
