FI Build
Old 07-21-2018, 11:53 AM
Subd
Subd's Avatar
Default FI Build
thought I would share my turbo build,
2003 nissan 350z manual, this isn't a guide or how to, Im not going to go in great detail of the parts ive picked or what ive done, will update
parts, thanks to www.conceptzperformance.com for all there help and info,
forgot to take a picture of the flywheel
first things first lets get the engine out,
being the genius that I am I forgot to evacuate the A/C, Oh well I can work around it for now
broom handle worked wonders holding up the hood, the previous owner was replacing the oil pressure sensor and tighten it way to much and cracked the upper oil pan, got a new upper oil pan from him when I bought the car,
taking out the engine was pretty straightforward, ive had more hard times taking 4 cylinder engines out,
what a mess,
block and heads and crank are at the machinist
for the turbo
with four valve engine w/variable valve timing 95% VE
215.73 x .5 x 3000rpm / 1,728 = 187.26 215.73 x .5 x 6200rpm / 1,728 = 387
187.26 CFM x .95 = 177.89 387 CFM x .95 = 367.65
10 + 14.7/14.7 = 1.68 15+14.7/14.7 = 2.02
177.89 x 1.5 DR = 266.83 367.65 x 1.7 DR = 625
266.83 x .069 = 18.41 625 x .069 = 43.12
18.41 lbs/min of air at 3000 rpm and 43.12 lbs/min of air at 6200 rpm
Garrett GT3582R
The following 4 users liked this post by Subd:
ajpasa (04-07-2020), bealljk (10-21-2020), OldManZ350 (04-03-2020), rustyschopshop (04-04-2020)
Old 07-21-2018, 12:17 PM
bealljk
bealljk's Avatar
right on ... great pictures!
what are you tuning with?
what are your power goals for the build?
Old 07-21-2018, 12:25 PM
WTFMike
WTFMike's Avatar
Awesome build. What turbo kit are you going to use? Or are you building your own?
Old 07-21-2018, 02:50 PM
Subd
Subd's Avatar
180hp @ 3000 rpm 440hp @ 6200 rpm
haven't decided what im going to be using for a tuner, up rev, haltech, (nissan opensource)
doing the turbo fab myself,
304 ss .0065
Old 07-21-2018, 04:08 PM
bealljk
bealljk's Avatar
Assuming youre using 304 for all the hot-side stuff?
I used .06" for my Y pipe and down pipes with a small ~2" section of ~.08" (I cant remember exactly) but if I had it all over again I'd make my down pipes thicker. With that being said, my .06" stuff has been doing fine.
Do you do your own TIG'ing??
Old 07-22-2018, 11:43 AM
Subd
Subd's Avatar
oil was leaking into the spark plugs chambers because of the worn out seals on the rocker cover,
you can see the saturated oil sitting on the bottom,
soda blasting the heads to save a couple of bucks or so I thought, machinist ended up putting them in the ultrasonic cleaner,
after soda blasting
heads are cleaned and the machinist is putting the new valve guides in,
Old 04-03-2020, 02:35 PM
Subd
Subd's Avatar
blocked cleaned, bored and honed, install ARP studs
got the crank cleaned and polished
The following 2 users liked this post by Subd:
Old 04-03-2020, 04:07 PM
OldManZ350
OldManZ350's Avatar
Looking Good!
But not much detail about the Motor, like what parts you used.
Old 04-04-2020, 09:20 AM
Subd
Subd's Avatar
haven't decided what turbo I'm going to use one on the right is a Garrett 60-1 the other is a rev 9 tx 72 38mm turbosmart wastegate (tech at turbosmart said that id be ok to use it long as it was 6 inches away from the turbo
The following 3 users liked this post by Subd:
Aeneas137 (05-11-2023), ajpasa (04-07-2020), OldManZ350 (04-04-2020)
Old 04-05-2020, 01:51 PM
Conway_160
Conway_160's Avatar
@bealljk I think you have another fabricator to contend with for sexy builds...
Old 04-05-2020, 02:12 PM
bealljk
bealljk's Avatar
Fine by me!
his look wayyyyyy better anyways!
jhc (04-05-2020)
Old 04-05-2020, 05:28 PM
jhc
General & Tech Moderator
jhc's Avatar
Without a doubt one of the best newb threds on this site ever, good luck on your project, keep updating and congratz!
"Subbed" for "Subd".
Old 04-05-2020, 05:44 PM
Subd
Subd's Avatar
thanks guys, I appreciate all the positive comments, Z community here seems great
Old 04-05-2020, 07:27 PM
bealljk
bealljk's Avatar
we got you fooled ... were a bunch of d!cks ... were just butter'ing you up and then we'll rip you down like the crazy narcissist we all are!! ha ha ha!
just kidding!
Great thread and keep up the good work!
The following 2 users liked this post by bealljk:
jhc (04-05-2020), travlee (04-06-2020)
Old 04-06-2020, 03:42 AM
Received 9,043 Likes on 6,509 Posts
i want all new posters in the FI thread to come see this..... he started 2 years ago, not sure of the delay, but they need to realize it takes time and not going to happen over a weekend
Old 04-06-2020, 07:40 AM
bealljk
bealljk's Avatar
marathon, not a sprint...
Old 04-06-2020, 09:54 AM
Subd
Subd's Avatar
Time, money and money,
Old 04-06-2020, 09:56 AM
exactly, time and time again we see people on here thinking they are going to do this or that, then either fail, dont realize the true cost or dont follow through.
good for you by posting the follow up.
Old 04-06-2020, 10:31 AM
Subd
Subd's Avatar
well I spent 6 months learning how to tig weld, physically doing it and watching countless videos on you tube,
spent a couple of weeks reading a great book called "Turbo: Real World High-Performance Turbocharger Systems" because I knew nothing about how turbos worked
watched 100s of fabrication videos, on youtube
Old 04-06-2020, 11:26 AM
bealljk
bealljk's Avatar
oh we beat it into them … they just don't listen, then call us ******!
yea … hat-tip … I got sick of a buddy thinking I was an open-check book and invested in a tig setup and I've screwed-up a bunch but I'm getting better.
Another good book (you've probably heard of it) Corky Bell's Maximum Boost - I still reference that book!
Quick Reply: FI Build
