Tomei Expreme ti Exhaust help
So i currently bought a tomei expreme i exhaust, its coming tomorrow thursday the 20th of sept. I know its all bolt ons and relatively an easy and quick install. My question is does it come with every piece required for the setup? All gaskets and harness and things like that? My friend had one on his wrx and he said he needed a gasket for his because it didn’t come with it in the packaging. I have a pic of all the parts off the website (Rallysportdirect) I bought it from. Thank you, if you’re going to be a ******** don’t respond. Also i have an 03 Z. This is also the link to the exhaust —— https://www.rallysportdirect.com/fit...t-back-exhaustp
Didn’t i say if you were gunna act like a ******** dont respond? Lmfao i did email them i just wanted a quick response rather then getting an email 3 days later after the fact. ****ing moron
Wow this was hard to find with a simple kindergarten google search:
Kit Contents
Kit Contents
- Main Pipe A
- Main Pipe B
- Silencer Assembly
- Gasket t=2.0mm
- Flange NutM10 P=1.25mm (2)
- Clamp Band "MIKALOR" SW2 79-85 (2)
- Spring (4)
- Silencer Band
- Silencer Band Rubber
- Bolt M8 L=25mm
- Nut M8
- Sound Reducer
- Button Bolt M6
- Allen Key
- Expreme Ti Sticker(2)
- Tomei Sticker(2)
- Bolt Smooth Paste
- Tomei Emblem
Kit Contents
Kit Contents
- Main Pipe A
- Main Pipe B
- Silencer Assembly
- Gasket t=2.0mm
- Spring (4)
- Silencer Band
- Bolt M8 L=25mm
- Nut M8
- Sound Reducer
- Button Bolt M6
- Allen Key
- Tomei Sticker(2)
- Bolt Smooth Paste
- Tomei Emblem
BluestreamDE (09-20-2018)
Last one I installed was complete, most quality parts come with everything needed. China junk and used is where the problems usually are.
Toasty
Originally Posted by RALLY SPORT DIRECT LITERALLY FROM THE EXACT LINK YOU POSTED
For those of you looking to add performance by losing weight and adding horsepower, then you will be pleased with the Tomei Expreme Titanium Cat-Back Exhaust System. This exhaust system has been fully fabricated from lightweight titanium and weighs 5.9 kg (13lbs). This exhaust system has been designed with minimal bends to reduce exhaust turbulence under acceleration which improves throttle response and adds both horsepower and torque.
This is a direct replacement for your factory equipped exhaust system, and exhaust hangers are welded onto the OEM locations so you don't have to perform further modifications to the body. There will be a sperate exhaust hanger included to position it the exhaust to your liking once installed. Also included with this exhaust is a new gasket, hardware, and the required clamps to make this exhaust system ready to install.
This is a single exit style exhaust that will not only save weight, but you also get the benefits of an improved sound, more horsepower, and more torque.
Hardware, gaskets, and clamps will be supplied to make this exhaust system ready for the installation.
So inspiring that an illiterate boy was able to get his drivers license. Truly an inspiration OP.
General & Tech Moderator
Who's got a Nm torque wrench I can borrow. And mb SAE conversion tables please?
