350Z Automatic Race Car? Auto Drivers Chime in (Champ/Chump Car)
Old 10-14-2018, 07:17 AM
the5
the5's Avatar
Default 350Z Automatic Race Car? Auto Drivers Chime in (Champ/Chump Car)
hey Guys,
I am interested in building a 350z for Champ Car formerly Chump Car.
The issue is to fit inside the Rules the car will have to be auto inside the rules.
I would put a hug cooler on it but will it be able to last the endurance race?
Also For those that have an auto track car, how do you guys like it and how are the shifts?
Old 10-14-2018, 08:14 AM
dkmura
dkmura's Avatar
Please explain why the automatic tranny is required to fit into champ/chumpcar rules? Seems a waste to run anything but the excellent 6-speed box in any form of road racing. Most of my students who had auto Z33s had severe overheating within 25 minutes of being on the track.
Old 10-14-2018, 04:54 PM
coletrickle74
coletrickle74's Avatar
Probably won't be good for endurance. I drive an auto with a cooler, fan, and a shift kit. Shifts great but it does over-heat as mentioned above. Usually within 15-20 minutes depending on the outside temperature. Hoping a deeper pan will help me out.
Old 10-14-2018, 06:04 PM
Please point to where it stipulates slushomatics are REQUIRED fare. I just went through all of of the ChumpCar rules and can find NOTHING regarding using a lazybox in a RACE car.
Old 10-15-2018, 04:52 AM
the5
the5's Avatar
While Not required Champ has a Points Based system. With the Auto car being 450 and the Manual at 525. Since its over 500 points it will start with a 3 lap Penalty ( every 10 points is one lap) and 6 laps in a 24 hour race.
the5
the5's Avatar
Which cooler do you have? Also do you shift electro-manually?
Old 10-15-2018, 05:54 AM
coletrickle74
B&M 11x7 inches. And of course, if I baby it and shift gears early and don't down shift too aggressively it won't over heat. But that's slow and not very much fun.
Old 10-15-2018, 09:09 AM
Ahh, so you want to try and actually WIN versus just finish. Hahahaha. But cool, ChampNeeChumpCar, LeMons.... cool way to race on a budget.
Old 10-15-2018, 09:32 AM
Let's look big picture.
03 to 05 Z in stick as we don't know if the auto will finish a race.
You will want an oil cooler, more points
you will need 06 or OEM brembo brakes
differential cooler could be a problem. I bet you will smoke the pinion bearing every 24 hour event, hopefully not earlier.
Front camber arms are almost a must, just for tire wear concerns.
shift at no more that 5500 rpm to not kill the MPG, basically drive with the torque.
Power Steering cooler is needed to survive
is this really the car you want for this series
DmanG281
03-09-2008 04:29 PM
Quick Reply: 350Z Automatic Race Car? Auto Drivers Chime in (Champ/Chump Car)
