350z Overheating.. HELP!!
So my ‘03 350z is overheating. The radiator, thermostat, and waterpump were all replaced. New head gasket and bleeder valve. Also, bleed the car for like 2 hours but once driving the car overheated again.. The fans still work and heater blasts but why is the car overheating..? Please help
Also, side note: S.E.S. Light is on and before the overheating the car when lump and the engine cut but all electrics work. The TCS OFF and SLIP lights both cam on afterwards as well. Upon checking codes this popped up: P0340- Camshaft Position Sensor A Bank 1. Does this mean the camshaft sensors and the crankshaft sensors are bad?
Almost identical issue on my 2003 Infiniti FX35, also has the VQ35DE, I was actually going to make a post but you seem to have somewhat similar symptoms. Here's my story:
Just replaced the head gasket (2 weeks ago), problem went away for 500km and came back today. For me, gentle driving seems to keep the issue at bay, but if I give it any more than 30-40% throttle, the following will happen:
When I replaced the head gasket, I didn't get the heads machined, so my current theory is that the heads were originally warped, causing the gasket to be placed under high stress in a specific location, which led to the subsequent failure after only a few hundred KMs with the new gasket. As was the problem originally, I think this is a microscopic, or semi-failed gasket which only leaks exhaust gasses into the coolant under high loads (higher cylinder pressures). When the exhaust gases enter the coolant system, I assume they travel into the water pump which causes the pump to stall (or "slip" in the gases) and cease proper operation. This then leads to the loss of coolant flow and subsequent loss of cabin heat, cooling of lower rad hose, cooling of bypass hose on the front of the motor, and overheat.
My plan as of now is to pull the heads, get them machined this time, install a new head gasket, and pray that this adventure is over.
Did you get your heads machined when you did the head gasket?
Does anyone else have any other ideas? I'm getting pretty close to buying a crashed up FX at an auction and swapping in another motor.
- Lose cabin heat (starts blowing cold).
- Coolant level slowly start to rise in overflow.
- Lower rad hose cools down.
- Bypass hose on the front of the engine slowly cools down.
- Engine temp slowly rises until coolant boils over and sputters out of overflow tank.
- I *THINK* I smell exhaust gasses in overflow tank.
¯¯\_(ツ)_/¯
Something like this?
If your heat is blowing cold, It's likely got air in the system because the coolant isn't passing through the heater core. . As much as you think you got it all out, I bet you didn't. Are you bleeding it with a Lisle funnel or just lifting the front and cracking the bleeder?
