Nismo 300km Dash Meter!!!
Hi I wonder anyone here install the Nismo 300KM Dash Meter Themselves? I bought a used one from Japan with only 26K km and I installed it myself and the next day when I drive the car for maybe like 5 mins it went into limp mode and CEL is on and I cannot drive past 3000rpm... and then I stop the car and restart CEL goes away and can drive normal again! Anyone experiences with this problem before? My Z is an AT!!!
Thank you for your reply but my Nismo Dash Meter is for AT... I know there's a manual version also! But I bought the one for AT. It is weird do I need to use the shop computer to reset something???? My car will goes into limp mode after driving for like 5 mins... turn it off and on again no more cel and drive normal????
Thank you Mr. Sparco, my car is in the shop now... do you give me some idea of how to TCM relearn??? My shop scan the code and said the Nismo Dash Meter is not cooperating with the throttle body and the transmission that's why it went into limp mode with CEL!!!
Try resetting all.
I would normally suggest google search or youtube but you guys must be really limited with China's firewall in place.
TCM relearn just disconnect the battery for a few minutes.
ECU code will have to be cleared with an OBD2 reader.
The throttle body relearn procedure copied and pasted from another site:
*Note timings are critical, it can be useful to have a watch with a second hand or use a mobile phone with stopwatch function to carry out the proceedures
Accelerator Pedal Released Position Learning
DESCRIPTION
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF and wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF and wait at least 10 seconds.
Throttle Valve Closed Position Learning
DESCRIPTION
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning
DESCRIPTION
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed under any of the following conditions:
Each time electric throttle control actuator or ECM is replaced.
Idle speed or ignition timing is out of specification.
PREPARATION
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
Battery voltage: More than 12.9V (At idle)
Engine coolant temperature: 70 – 100°C (158 – 212°F)
Park/neutral position (PNP) switch: ON
Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, if the parking brake is applied before the engine is started, the headlamp will not be illuminated.
Steering wheel: Neutral (Straight-ahead position)
Vehicle speed: Stopped
Transmission: Warmed-up
For A/T models with CONSULT-II, drive vehicle until “ATF TEMP SE 1” in “DATA MONITOR” mode of “A/T” system indicates less than 0.9V.
For A/T models without CONSULT-II and M/T models, drive vehicle for 10 minutes.
OPERATION PROCEDURE
NOTE:
It is better to count the time accurately with a clock.
It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit
has a malfunction.
1. Perform EC-77, “Accelerator Pedal Released Position Learning” .
2. Perform EC-77, “Throttle Valve Closed Position Learning” .
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the
specifications.
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried
out successfully. In this case, find the cause of the incident by referring to the DIAGNOSTIC PROCEDURE
below.
If Idle Air Volume Learning cannot be performed successfully, proceed as follows:
1. Check that throttle valve is fully closed.
2. Check PCV valve operation.
3. Check that downstream of throttle valve is free from air leakage.
4. When the above three items check out OK, engine component parts and their installation condition
are questionable. Check and eliminate the cause of the incident.
It is useful to perform EC-132, “TROUBLE DIAGNOSIS – SPECIFICATION VALUE” .
5. If any of the following conditions occur after the engine has started, eliminate the cause of the
incident and perform Idle Air Volume Learning all over again:
Engine stalls.
Erroneous idle
DESCRIPTION
OPERATION PROCEDURE
DESCRIPTION
OPERATION PROCEDURE
DESCRIPTION
PREPARATION
OPERATION PROCEDURE
NOTE:
has a malfunction.
specifications.
below.
Engine stalls.
Erroneous idle
DB8
Interior
02-03-2013 08:47 AM
big_dish
Interior
19
06-17-2012 01:05 PM
