Brand new clutch going out?
Old 03-11-2019, 03:33 PM
Beau.2001
Beau.2001's Avatar
Default Brand new clutch going out?
hey guys this will be my first post on the site, I have a 2006 de rev up with the 6spd and just hit 150000 miles. About 3400 miles ago I replaced the clutch. Well as of last Friday I was out with some buddies doing donuts and I clutch kicked on dry pavement did about 2 full circles and my car started trippin up so I stopped, I thought I was driving but I coasted to a stop in a parking spot. Tried to restart the car and wouldn’t turn. Only thing that was coming up was the battery light but voltage was still good. We put it on jumper cables and waited a few minutes and started the car. After that I drove maybe 100 yards and a CEL came on and my car was shifting really hard with not much power. Came to a stop light downhill and the car stalled. It started up right away and I started driving the highway back at about 50-55 but car was still shifting hard. Next day come to find out both camshaft sensors needed to be replaced so I did so. Car seemed to run good until about 4500 rpms then would rev slowly but wouldn’t accelerate so I assumed it was clutch issues. Drive the car to school today and it would die if I stopped somewhat fast I guess you would say. On the way home pull in away from a stop sign the car stalled. Pulled over started it and drive 10feet stalled again so I pushed it up the road and when I got home same thing. Started then when engaged immediately stalled. Gave it about 10 min then drove the car up the driveway. I’m really struggling because I have no CELs but I want to be sure it’s my clutch before I drop the trans AGAIN.... please help me.
Old 03-11-2019, 04:19 PM
Spike100
Spike100's Avatar
I doubt it is the clutch causing this. Sounds as though your car is in limp mode. Spinning the car's rear around ("donuts") can cause this.
What made you think that the camshaft sensors required replacement?
Old 03-11-2019, 04:44 PM
Beau.2001
Beau.2001's Avatar
i had a CEL and got it checked at auto zone
Beau.2001
Beau.2001's Avatar
My clutch also feels like complete ****
Old 03-11-2019, 04:49 PM
Spike100
Spike100's Avatar
Well, that's new information. A damaged clutch can put you into limp mode. If your clutch feels that bad, that is a place to start since you need to fix this anyway.
Old 03-11-2019, 04:51 PM
Beau.2001
Beau.2001's Avatar
Do you think it could have damaged a clutch that only has 3500 miles on it? Given I’ve drifted/ donuts before but could that be possible?
Old 03-11-2019, 04:58 PM
Spike100
Spike100's Avatar
Yes. The clutch is your "safety valve" in the drivetrain. This is the component that is designed to go first if the drivetrain is overly stressed. It protects your transmission and driveshaft/differential.
Old 03-11-2019, 05:03 PM
Beau.2001
Beau.2001's Avatar
I heard from a buddy I could be the MAF would that be possible?
Old 03-11-2019, 05:10 PM
Spike100
Spike100's Avatar
Does you buddy own a donut shop?
____________________________________________________
EDIT
Ohh… I see the corrected typo (MAF instead of "mad"). More likely the ECU. You can do a reset.
But, if your clutch feels really bad, that will also need repair.
Old 03-11-2019, 05:15 PM
Beau.2001
Beau.2001's Avatar
No sir he owns a FD3rs hahahaha
Old 03-11-2019, 05:22 PM
Beau.2001
Beau.2001's Avatar
How would I go about resetting the ECU??
Old 03-11-2019, 05:27 PM
Spike100
Spike100's Avatar
Do a google search: "Reset 350z ECU"
It would be wasteful to post the instructions here when they are available all over the place.
Old 03-11-2019, 05:28 PM
Beau.2001
Beau.2001's Avatar
Thank you!
Spike100 (03-11-2019)
Old 03-12-2019, 03:38 AM
Received 9,046 Likes on 6,512 Posts
jeebus....we may have a new dugan contender
Old 03-12-2019, 07:16 AM
bealljk
bealljk's Avatar
Them some expensive doughnuts!
Old 03-12-2019, 11:42 AM
Beau.2001
Beau.2001's Avatar
Very...
Old 03-12-2019, 12:52 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Sounds like a good time
Old 03-19-2019, 11:05 AM
Nismo350z#0310
Nismo350z#0310's Avatar
What have we learned from this?
Not to treat the things you care about / depend on like trash lest it become trash? Possibly!
Old 05-03-2019, 07:09 AM
Beau.2001
Beau.2001's Avatar
Hey guys! Just got the new clutch installed and have a starting issue! Everything is hooked up and seems to be functioning correctly. The only problem I have is that it won’t start. I’m pretty sure it’s the batter but I just wanted some other brains to see if it’s something else. My old battery off the Z was put in another car and the hood got stuck! So I used the battery out of that car that sat for about a year and a half and tried jumping it and didn’t work. Also put the batter charger on 12/2 and let that sit for about three hours and still wouldn’t crank. Just a small click and then done. Any ideas or should I just go grab a new battery!? Thank you for all of the help and responses on the thread it means a lot!
Old 05-03-2019, 07:17 AM
def battery
Quick Reply: Brand new clutch going out?
