LED Map/Dome light issue
Hey, this might be a really obscure problem and question.
I recently put RGB LED panel lights into the 350z map/dome light. These are super bright and can change color.
BUT
I have an issue...
Since our map/dome lights fade both on and off when the door is closed, the LED freaks out and flickers and turns itself off. I assume this is because the LED only wants 12v or 0v and our map/dome lights slowly get to 12v when turning on and slowly get to 0v when turning off.
Is there any way to make it only 12v and 0v? Is there something I can wire in or something I can remove to achieve this?
Hopefully thats understandable. Thanks!
BUT
I have an issue...
It sounds like the LEDs that you're using are not dimmable so that's why they flicker as the voltage drops. I'm not certain, but you could try adding some type of LED dimming resistors/controls, but there's not a lot of space in the dome light area. The better solution may be to get LEDs that are dimmable.
When I added footwell lights, I tapped into the dome light circuit and they slowly fade off similar to the dome/map lights, but I used LEDs that were dimmable.
I basically have no advanced electrical knowledge though and don't know if I would have to add in anything else along with the diode.
Wondering if anyone has any know-how.
Picture is my LED RGB Panel light.
You don't want a Zener Diode. You could try a 1K 1/4W resistor and 10uF cap in parallel with the led light. Might help or at least reduce the flickering. If that doesn't work you could increase the capacitor maybe up to 47uF or 100uF.
nzl_truly (03-25-2019)
Would I have to add that to each panel or could I add it to the harness to the dome light instead? Thanks
avandss
28
06-03-2013 07:20 PM
Gozirra
Vendor Wanted
09-21-2012 08:00 PM
