My 05 350z stops accelerating in the freeway
Old 07-16-2019, 12:39 AM
Ernestoxaboytes
Ernestoxaboytes's Avatar
Default My 05 350z stops accelerating in the freeway
My 350z stops accelerating in the freeway, the only way it will accelerate again is if I put it in neutral for a bit then back into gear. I’m thinking it’s an exhaust leak because I do hear a hissing noise but I’m not sure if that’s what’s causing the car to stop accelerating
Old 07-16-2019, 02:45 AM
813_350Z
813_350Z's Avatar
Is your CEL or Slip light on?
Old 07-16-2019, 03:07 AM
Ernestoxaboytes
Yes, my slip light turns only when it happens then goes away
Old 07-16-2019, 03:28 AM
813_350Z
813_350Z's Avatar
Your tires aren't worn, are they? Is your car equipped with VDC? It sounds like VDC is kicking in. Is it under hard acceleration, or just cruising?
Old 07-16-2019, 03:33 AM
Ernestoxaboytes
No they’re not worn but I did get new control arms & need my car aligned because I got into an accident but not sure with the vdc & just cruising
Old 07-16-2019, 03:47 AM
813_350Z
813_350Z's Avatar
I would run a scan just to ensure you are not throwing any DTC's that aren't triggering your CEL. I have had the same happen and it ended up being camshaft sensors. I was cruising at the time also when I lost power.
Get your car aligned and double check to ensure everything is within specs with respect to your CA's. If something is off, you car will misread that and trigger your VDC, throwing your slip light on and cutting power to compensate.
khnitz (07-16-2019)
Old 07-16-2019, 04:31 PM
Ernestoxaboytes
So I got it aligned & scanned it again & there’s a shortage, it can be a camshaft or my catalytic converter because there is a whole
Ernestoxaboytes
Hole*
BigChuneZ
06-22-2017 04:43 PM
Picketttorri
11-30-2015 10:00 AM
jonandol
06-19-2014 10:51 AM
AnthonyNHiS350
04-19-2012 06:43 AM
SuperB350Z
04-08-2010 10:07 AM
Quick Reply: My 05 350z stops accelerating in the freeway
