LOUD exhaust noise
LOUD exhaust noise
Hello everyone, I have an 06 DE with Z1 test pipes, Z1 y pipe, and Z1 single exit. Since removing the Borla that was on the car when I bought it and replacing it with the Z1, during slowdowns from 3k-1.7k, the infamous VQ "hiss" is pretty loud and quite frustrating. I have removed it, disassembled it, checked every single gasket and even replaced them with all new gaskets just in case and it still does it. I reinstalled it and everything is perfectly in place and torqued to spec. Could this be due simply because of the excess air flow in the exhaust as well as the test pipes being non-resonated? It isn't something that will cause me to get rid of the car or replace the exhaust if it isn't an actual problem. Any feedback is appreciated. Thanks!
khnitz (07-18-2019)
I have the exact same setup, though I have Tomei V2 headers as well. I wrapped the entire setup to cope with hissing and drone, and that's good enough for me. I keep the silencer in unless I'm on track though. Have you verified there's no leak on the swedge joints on the y-pipe? It took multiple attempts to have it not leak.
The noise itself isn't a problem, I've read the hissing is a combination of increased flow from test pipes, and through a y-pipe. This y-pipe idea has some merit, I don't recall ever hearing of anyone with a true dual exhaust having this noise.
jellofuel (07-16-2019)
Honestly when you install parts which make the exhaust the loudest, there are going to be related noises. You can wrap the exhaust but wrapping on a street car can make the pipes more prone to cracking especially if driven in the rain.
813_350Z (07-16-2019)
You went over the entire system, ensuring that every gasket was in place and in working condition, and that the system was "perfectly torqued". Which leads me to believe that there is nothing wrong with the system meaning A. You didn't do a thorough enough inspection and something is, in fact, wrong and is causing your problem, or B. You did not listen to how the system sounded prior to purchasing it and no realize that you don't like it now that it is installed.
So you have four options, take it to a shop who will actually confirm that the system is in good working condition or not, swap the Borla system back on it ( or buy something else if you prefer), live with it, or sell the whole car (idiocy if you ask me, but W/E)
I had the notion that I was going to hear a lot more of those noises that were "hidden", for lack of a better term, but I figured I'd ask about this one because it seems to be the most prominent one. Thanks though!
Yeah I've never heard of any true duel doing such a thing either. It didn't do it when I had the Borla on there. And forgive me, by swedge joint you mean? I'm assuming where the separate "y's" slide into the connector? Also, wrap worked for you? I was thinking about wrapping a portion (if not all) of the exhaust to aid with some excess noice from the rumble of such a loud and large diameter exhaust but haven't got around to it yet. All in all, I absolutely love the exhaust and how loud it is. I'm going on a dyno for a tune in a couple of weeks and just want to make sure the Z is ready for it. After all, this is the only problem I have with the car.
The wrap was enough for me, but it doesn't sound as good as other exhausts, so I keep the silencer in. The silencer really helps with excessive rasp as well as overall volume. I've never personally heard of an exhaust cracking because it's wrapped (not saying this can't happen), and I figure if there's any concern for cracking, it's because there are no flex pipes on this exhaust setup. If I'm honest, I'd just get the tune, and once you're happy with the numbers, keep everything as is.
Yes, the piping of the y that slides into the connector. I've heard reports from fellow Z1 customers regarding the leaking joints. I saw one guy on FB so desperate for a fix he welded it lol
kamilswift
08-05-2012 10:15 AM
kamilswift
08-04-2012 08:25 AM
