Vortech Belt Slip/noise Solution
Old 10-07-2004, 05:36 AM
OldManZ350
OldManZ350's Avatar
Default Vortech Belt Slip/noise Solution
Vortech Belt Slip/noise Solution-Fix
I have corrected the problems with the Vortech Drive Belt and Pulleys.
It works Great. No Belt or pulley noise. The Belt no longer has to be so tight that is stretches.
1. Machine the Stock Fixed Idler Pulley (for flat side of Belt) Machine just enough to remove RIBS and side to side so the Belt sits Flat in Pulley
2. Purchase a 12mm x 110mm Hex Head Bolt and machine (or grind) the Head Hight down to about .200 in.
3. WRONG>>>>> Purchase a 92-1/8 long V-Belt Gates # 060915 (for 2.87 Dia Pulley or a Delta 060923 (for 3.31 dia Pulley)
CORRECT>>>> My Belt is 91-1/4” Long with a 2.87 Pulley. Napa/Gates Micro-V 060908
4. Remove the Vortech middle Idler Pulley.
5. Route the Belt around the Crank, under and around the the Fix Idler to the Blower, over the top Idler, under the lower Idler to the power steering pump, around the Alt and over the Adj Idler.
Last edited by OldManZ350; 01-17-2018 at 11:26 AM. Reason: Changed Belt Length......
Old 10-07-2004, 11:01 AM
SungNamZ
SungNamZ's Avatar
Definately want to see "Pictures"! I immediately replaced my "Gator" belt with a "NAPA" belt. Works GREAT, but would still like to get rid of some "noise".
Old 10-07-2004, 01:17 PM
booger
booger's Avatar
I dont know if you could get a good pic of the routing of the belt...could you draw a diagram to show us the routing also....thx
Old 10-07-2004, 03:16 PM
OldManZ350
OldManZ350's Avatar
Default Vortech Belt Slip/noise Solution-Fix Pics
Attached Thumbnails Vortech Belt Slip/noise Solution-pa060001.jpg
Old 10-07-2004, 03:42 PM
booger
booger's Avatar
I dont know the pulley names . But the one with 4 set screws on it , is the one you milled off the grooves ? And just removed the middle pulley and used the purchased 12mm bolt to replace the one used on the removed pulley ? Im just wondering if your going to have enough........gripping area... the belt will be touching less area of the jackshaft pulley . The belt is coming from a wider angle than before . Im just looking at mine and your pic at the same time and think about possible problems with it . Im not trying to take away from your idea...its a good one....Lets us know how it comes out in the next couple weeks....slipping or not.....It will be a easy replace if it does slip......Bill
Old 10-28-2004, 08:10 AM
OldManZ350
OldManZ350's Avatar
bump
Old 10-28-2004, 08:12 AM
OldManZ350
OldManZ350's Avatar
bump
Old 11-01-2004, 04:25 PM
gspot35
gspot35's Avatar
Originally posted by TIMROD1011
bump
Bump =???
Old 08-12-2005, 07:42 AM
OldManZ350
OldManZ350's Avatar
Layout Drawing Attached
File Type: doc
Old 08-12-2005, 02:06 PM
booger
booger's Avatar
thanks Tim . I can see exactly what you was talking about now . I may see if I can buy a stock fixed idler pulley and have it milled off . So I can put it back to stock if need be.
Old 10-31-2005, 07:38 AM
OldManZ350
OldManZ350's Avatar
bump
Old 10-31-2005, 08:28 AM
sentry65
the burninator
sentry65's Avatar
does someone know where to buy these belts from?
Old 10-31-2005, 11:58 AM
Brando
Brando's Avatar
3. Purchase a 92-1/8 long V-Belt Gates # 060915 (for 2.87 Dia Pulley or a Delta 060923 (for 3.31 dia Pulley)
Pictures will be posted tonight.
Timrod
Very interesting.....
Ok....I think I got most of it.....
But please explain step 2 - head height .200 ???????
Thanks!
Old 01-26-2007, 01:02 PM
sentry65
the burninator
sentry65's Avatar
back from the dead
everyone who's done TIMROD's new belt solution, I need to know where you bought that idler pulley from and what the part number is.
I'm having a hard time finding something that'll work.
here's a before and after picture of his modification, with the only difference being that I have added an additional idler pulley near the jackshaft pulley. Hell, you might even be able to take the one that you remove and put it there
Attached Thumbnails Vortech Belt Slip/noise Solution-stock_belt_setup.jpg   Vortech Belt Slip/noise Solution-new_belt_setup.jpg
Old 01-26-2007, 01:24 PM
booger
booger's Avatar
Your idea really helps what Timrod did . The farther you can get it to the left and up , the more it will help . Hope you can make it to adjust or tighten up more than shown . good idea !
Old 01-27-2007, 06:19 AM
Gilley
Gilley's Avatar
No belt slippage yet with the new Gates, but I'd like to know where to get the idler pulleys too, just in case.
Old 01-27-2007, 08:05 AM
sentry65
the burninator
sentry65's Avatar
You machine the stock idler pulley it turns out - I just didn't read over TIMROD's post closely enough
Old 01-27-2007, 10:11 AM
Bwicked
Bwicked's Avatar
what i ask them to machine the stock pulley, what do i say exactly lol? is there a certain way or length they do it? for example u said hex oblt machined down to .200 in.
Old 01-27-2007, 10:12 AM
sentry65
the burninator
sentry65's Avatar
I think you just have the ribs machined off until it's a smooth surface
Old 01-27-2007, 05:58 PM
Audible Mayhem
My350z
Audible Mayhem's Avatar
cog belt snapped right in half today tuning on the dyno...
Quick Reply: Vortech Belt Slip/noise Solution
