Something's wrong with my car =(
Awhile back, I installed the AEM CAI into my Z with the help of the instructions that came in the box. After a couple days with it on, the car does a sort of dance, like it'll jerk back and forth while driving. The next day, the problem went away, but i noticed that it does the same dance when the car is wet. What's the problem? Where can i get it fixed? Help please!
are you talking 'bout hesitation? like the car is moving forward, then all of a sudden lurches?
check your hose connections and make sure your battery connection is secure. please describe it a little better than 'dancing when wet' |
sounds like a unsteady idle.......if so did you disconnect the battery when you installed
Is the filter on correctly, How about the air sensor? You might of put it back wards. It should be a easy install with no problems. I have the injen cold air and never had that problem. I will re instasll just to make sure the process was done correctly.
It isn't hesitation. It's kinda like while your driving it suddenly brakes then jerks forward.
I disconnected the battery before i installed the intake. The filter is on correctly (how can it not be?). I put the air sensor in the correct way. I'll try re-doing the install. |
| All times are GMT -8. The time now is 12:12 AM. |
