problems with installing y pipes
Old Mar 6, 2007 | 05:04 PM
Nato's Avatar
Nato
Default problems with installing y pipes
just got my y pipes today unbolted everything excpet the driverside bolt of the 3in exit tryed with impact gun ended up just striping the bolt i couldn't beleave it been trying to get the damn thing off for the last hour now im at the point were im just gonna cut it off anyone else have any problems with there y pipes install??? i got 06 base
Old Mar 6, 2007 | 05:18 PM
Nastyboy's Avatar
Nastyboy
Hmm.... I have switched more than my fair share of Y-pipes and the only thing I can advise is try wedging a flat screwdriver between the bolt and metal when you try to unscrew it. Hope that makes sense.
If it's still driveable, feel free to stop by and I'll help.
-Nasty
Old Mar 6, 2007 | 08:22 PM
DRFT_Z33's Avatar
DRFT_Z33
You can try to soak it with wd-40 and let it sit overnight then try again in the morning. A 6 point socket would probably be your best bet if it isn't totally rounded off.
I rounded off one of the bolts on my lower control arm changing my springs and thats how I got loose...
Old Mar 6, 2007 | 09:45 PM
blaukal's Avatar
blaukal
when you saw "stripping the bolt" do you mean the welded bolt? or the nut? either way you're probably looking at grinding the head square again. a little grind and a little lube and you should be good to go.
Old Mar 7, 2007 | 12:44 PM
Nato's Avatar
Nato
it was the nut im just gonna cut it off im using new hardware anyways just wanted to see if anyone else had any problems with theres
Old Mar 31, 2007 | 07:09 AM
three_fitty's Avatar
three_fitty
I gots the same problem. The 2 bolts on the exit side of the y-pipe. Such a b*$&h to get off. I rounded one of them too, gave up last night. We'll try again to today. Good luck with yours.
Old Mar 31, 2007 | 08:22 AM
ecorona6's Avatar
ecorona6
I always squirt some wd-40 or liquid wrench before unbolting these type of bolts. It doesnt take much to have a bolt get stuck when its subjected to so much heat. Good luck
liqalu04
Jan 2, 2022 12:58 PM
Justin100
Nov 29, 2015 03:58 PM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
