MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Suspension (https://my350z.com/forum/suspension-415/)
-   -   It's all about STANCE! Real Quality Coilovers @ a Great PRICE @ S&R! (https://my350z.com/forum/suspension/496365-its-all-about-stance-real-quality-coilovers-a-great-price-s-and-r.html)
S&R Performance Aug 6, 2010 06:53 AM
A well prepped suspension does wonders for the car and in the world of knock offs, cheap copies and just poor quality, STANCE rises above most others with quality, performance and reliability!
These coilovers have become an industry standard over the years and we can't say enough about them. We have the entire line up available for your build! Check out the models that are available for you Z/G setup!
STANCE GR+
http://www.sandrperformance.com/asse.../stance/gr.jpg
The GR+ is the Stance flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
Features:
* Adjustment Knob15-Way Damping Adjustable
* Upper Pillowball Bearing
* Spring Cold Wound Linear Spring
*Monotube Shocks
* Dustboot
* Collar Aluminum Collars & Upper Mounts
* Bracket Height Adjustable Lower Bracket
DETAILS HERE!
S&R Performance Aug 6, 2010 06:58 AM
Stance gr+ pro
STANCE GR+ PRO
http://www.sandrperformance.com/asse...ance/grpro.jpg
GR+Pro coilover have all the features of the GR+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
* Monotube Shocks
* Dustboot
* Rear Helper Spring
MORE DETAILS HERE
S&R Performance Aug 6, 2010 07:05 AM
STANCE GR+ Pro SS-D
STANCE GR+ Pro SS-D
http://www.sandrperformance.com/asse.../grpross-d.jpg
GR+Pro [SS-D] The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The GR+ Pro SS-D were used to win national titles in both drifting and time attack; setting the highest benchmark for itself - winning.
These coilovers feature a 16K front and 14K rear sprint rate, needless to say, these are for anyone looking to do some work on the race track. This kit features the OEM style rear assembly.
* Monotube Shocks
* Dustboot
* Front Helper Spring
MORE DETAILS HERE
S&R Performance Aug 6, 2010 07:07 AM
STANCE AL+ Pro
STANCE AL+ PRO
http://www.sandrperformance.com/asse...ance/alpro.jpg
AL+Pro is based on our popular GR+Pro model. AL+Pro features full aluminum shell construction which has excellent anti-corrosion characteristics for customers that see extreme weather conditions. The aluminum shell casing is also lighter than steel, providing less unsprung mass for greater response. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
This kit uses the single piece rear suspension assembly.
12K Front / 5K Rear Spring Rates
* Adjustment Knob 15-Way Damping Adjustable
* Upper Pillowball Mount
* Springs Cold Wound Linear Spring
* Monotube Shocks
* Dustboot
* Collar Aluminum Collars, Upper Mounts & Shock
MORE DETAILS HERE
S&R Performance Aug 6, 2010 07:16 AM
THE BIG BOY TOYS!!! GR+ 3 Way Coilovers w/ External Resevoirs.
STANCE GR+ 3 Way Coilovers
http://www.sandrperformance.com/asse...nce/gr3way.jpg
GR+3 is our top of the line coilover. The GR+3 features 3-way adjustability, enabling the driver to fine tune low-speed and high-speed bump separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
REBOUND Rebound adjustment controls body roll. It is used to add high speed stability and the rate of weight transfer.
HIGH SPEED High speed compression adjustment is effective in controlling the overall chassis movement and harshness over bumps.
LOW SPEED Low speed compression controls the roll, pitch and how quickly weight is transferred to each corner. It is effective in adding turn-in response & providing feedback to the driver.
FEATURES
* Spring SWIFT Spring
* Monotube Shocks
* Boot Dustboot
* Bracket Rear Helper Spring
* External Reservoir15-Way Low-Speed Bump & 4-Way High-Speed Bump Adjustment
These are a real performance coilover! If you're serious about getting into racing, this is what you need.
S&R Performance Aug 6, 2010 08:23 AM
45 views and no questions? Come on people, don't be shy. We're here to help.
k6750gsxr Aug 6, 2010 05:40 PM
Bump for a awesome set of coils.
ChrisR Aug 7, 2010 01:56 PM
stance gr+ picked up
S&R Performance Aug 9, 2010 08:02 AM
pricing PM's on the way, folks! Thank you for your consideration.
DANIELV12 Aug 9, 2010 09:24 AM
PM sent thanks
S&R Performance Aug 9, 2010 09:39 AM
got quite a few. thanks folks! Replies on the way.
sdZ33 Aug 18, 2010 02:53 PM
GR+ true and OEM type shipped to 92104
S&R Performance Aug 23, 2010 10:05 AM
STANCE BABY! Make yo STANCE right!
Blackheart Aug 24, 2010 07:31 PM
1 GR+ Pro to 77469 please thank you
S&R Performance Aug 25, 2010 12:49 PM
http://www.sandrperformance.com/Stan...ers_p_347.html ; ) PM on the way.
S&R Performance Sep 17, 2010 11:06 AM
set of GR+ on the way out the door! Thank you for your business, folks!
angryCOWofDOOM Sep 18, 2010 02:09 AM
Stance GR+ and GR+ Pro shipped to 95219. Thanks
S&R Performance Sep 21, 2010 07:50 AM
hey dude, $1279 on the GR+ SHIPPED! GR+ Pro is $1349 shipped. Please let me know if you have any other questions. I hope to get a chance to earn your business.
S&R Performance Sep 25, 2010 06:26 AM
Thank you all so much for your business! Monday, I'll have some new bundles posted to help you all save as much money on quality parts as possible!
PikeZ_350 Sep 29, 2010 06:07 AM
How much for GR+ Pro shipped to 27610? Thanks.
