FS: KW Variant 3 w/ Swift springs
Old 05-12-2019, 07:43 PM
Avari
Default KW Variant 3 w/ Swift springs
Have a set of KWv3 Coilovers (dual adjustable with external res) that I just took off my 2005 350z. Should fit any z33 or g35. All in working order. Rears were sent to KW for a rebuild about 3,000 miles ago. Set was on the car when I purchased it, Fronts probably have about 10k. No visible leaks and all the adjusts work. Rings all spin freely, they are all stainless steel bodies so everything is clean and functional.
I have upgraded them with a set of 60mm Swift springs, 7" 12k front, and 6" 10k rear w/ a 50lb helper. The rear spring sits a bit low for some people, but I ran them for a year without a problem. You might want to grab a pair of 7 inch springs to fix it, or if you just want the best DD ride in the world swap on the KW included springs. KW springs saw some life on Road Atlanta and have some paint missing towards the bottom, and one of the rear dust protectors has had a crack since I have owned them.
This car is a dedicated autox car running the SCCA STU class. Upgraded shocks to get some drastically higher spring rates, too much for these KWs. These are exceptional as a daily set or for track/autocross use. Car was fast.
These retail for about 2400 plus another 400 in the swift springs, helpers and mounts. Asking $1700 firm, for now.
Avari is offline
Old 05-13-2019, 05:22 PM
Avari
Willing to split the Swift spring setup and sell just the KWs for $1400+shipping
Avari is offline
Old 05-19-2019, 03:55 PM
Avari
Swifts Removed, Cleaned up Springs. Everything set to factory recommendations. $1400
Avari is offline
Cux350z
Suspension
09-15-2015 06:26 AM
Mutt
03-08-2013 02:23 PM
KamiSpeed
Suspension
54
12-07-2010 01:40 PM
Ge|atinousFury
06-26-2008 11:50 AM
Ge|atinousFury
06-25-2008 10:26 PM
Quick Reply: FS: KW Variant 3 w/ Swift springs
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
