GReddy V-manage (Variable Valve Timing Controler)
I Was Checking GReddy Website and i just found that they came up with this device and here is the Information for it
V-MANAGE (VARIABLE VALVE TIMING CONTROL UNIT)
Part No 15500551
* Freely adjust valve timing on Variable Valve Timing vehicles.
* Fast USB data communication.
* Simultaneously data log with e-manage Ultimate.
* DIP switches available to activate and deactivate maps. Turing all dip switches off will return cam timing to stock.
* Up to 4 channels available. (V-type and boxer engines).
* Adjust VTEC and VVTL-I crossover points.
<MAP>
* Valve Timing MAP ? 16x6 MAP to input valve timing.
* Valve Timing Adjustment MAP ? 16x16 MAP to adjust valve timing.
* VVL MAP/VTEC MAP ? 16x16MAP to adjust crossover points.
<Data Logger>
* Valve Timing (ECU), Valve Timing (MAP) and Valve Timing (Measured) display.
* VVL, VTEC ON / OFF display.
SUPPORTED VEHICLES
TOYOTA
VVT-i : 2JZ, 1JZ, 1SZ,2NZ,1MZ,1NZ,1ZZ,3S,1G,2AZ
VVTL-i : 2ZZ-GE
DUAL VVT-i : 3S-GE
SUBARU
AVCS : EJ207
HONDA
i-VTEC : K20A
NISSAN
CVTC : VQ35DE (except Z33 anniversary)
MITSUBISHI
MIVEC : 4G63
for more info check these links
http://www.trust-power.com/03electric/vmanage.html
http://www.trust-power.com/03electri...t_vmanage.html
http://www.trust-power.com/06new/e20...6_vmanage.html
http://www.trust-power.com/06new/e20...e_harness.html
MSRP is 50,000 JPY = $417
Available March 2007 according to http://www.mohdparts.com/emanage/index.html
Part No 15500551
<MAP>
<Data Logger>
SUPPORTED VEHICLES
TOYOTA
VVTL-i : 2ZZ-GE
DUAL VVT-i : 3S-GE
SUBARU
AVCS : EJ207
HONDA
i-VTEC : K20A
NISSAN
MITSUBISHI
MIVEC : 4G63
Originally Posted by QuadCam
Basically, it won't work on the Revup.
NISSAN CVTC ......VQ35DE (Z33 latter-term MT35th Anniversary exhaust side eVTC after the September of 05 operational lack of confirmation)
Don`t gave up man still there`s a chance even if it didn`t work don`t forget the Firmware upgrades i`m sure they will take care of this issue
on
Originally Posted by Audible Mayhem
good, now i can just put a different throttle body on my car with that greddy and do ANY stand alone that i want....
Why would that allow any TB?
on
It is possible that this black box just alters the cam position signals to get the ecu to position the cams where you want them to be.
If it iindeed can be used as a standalone vtc controller, then it has to send false cam position signals back to the ecu to prevent it from throwing the P0011 and P0012 codes.
I am looking to use one of these for my application so I am hopeful that it does offer its own internal pwm control functions.
Also, if you look at your stock VTC phaser control angle vs rpm curve, you are probably not going to gain much from this unless you are running more aggressive aftermarket cams and/or the increased range Nismo VTC phasers.
UltimateSleeper
Yeah I'd like to know if this is a piggy back or a standalone also. Given that it lists two different types of control, Valve Timing MAP ? 16x6 MAP to input valve timing and * Valve Timing Adjustment MAP ? 16x16 MAP to adjust valve timing, it may very well support both, perhaps that's wishful thinking.
Bottom line, is that we'll have to see the wiring diagram, then it might be a clue.
