Haltech base map/1000cc's.
Built engine,1000cc's HKS injectors, GTM STG 2 TT kit, full RFS.
Just to let the car drive in vacuum to break in the new engine. I already got one from Hal, it start up great,but drive really bad.(too much fuel) I tried to pull fuel, and end up pulling around 70% in the lower vacuum cells just to make it idle at 14-15afr.:o I can't do that to all cells in vacuum, kinda nope here and don't want to f*** things up. Thanks in advance. |
so whats the question?
Originally Posted by str8dum1
(Post 8665912)
The one I got is for a built engine with a way smaller injectors than mine. |
You can change the dead time to affect the entire map at once, if it's rich across the board. Just change the cell at the voltage that the car is running at.
so why can't you go and adjust all the cells?
I had to adjust everything on my fuel map when going from dw 800's to hks 1000's. Just drive it, log, and just |
Originally Posted by rcdash
(Post 8706378)
i'm trying to adjust it well, but couldn't do much with my target AFR, so i went and played around with Base Fuel, and got it to run a bit better, but still not the best. |
| All times are GMT -8. The time now is 12:37 AM. |
