GTM Performance Engineering 350Z HR SUPERCHARGER KIT PRESS RELEASE
40 Attachment(s)
We are please to announce the GTM supercharger system for the 350ZHR. Our GTM supercharger system will be utilizing the Rotrex C38 supercharger, The Key to the Rotrex supercharger is unique compactness, efficiency, low noise and reliability and its state of the art traction drive technology.
Great speeds and low noise are just some of the advantages of traction drives over traditional gear transmissions. Traction drives transmit power through friction forces between its rolling elements. The Rotrex traction drive uses an elastic annulus with a small pre-span to secure contact between the roller planets and the sun shaft with a reasonable force. The patented "ramp effect" increases efficiency and reliability in the transmission by regulating the torque transfer capability on demand through self-adjusting planet geometry. To enhance performance, the Rotrex traction drive uses a special traction fluid. These fluids are a new family of synthetic hydrocarbon oils and greases offering a series of unique performance advantages. Developed specially for its use in Rotrex superchargers, the SX100 momentarily increases viscosity under high surface pressure, enhancing the traction drive performance by securing the optimum friction between rolling elements while cooling and protecting the system. This traction drive combined with the latest technology in centrifugal compression, characterized by high adiabatic efficiency and low noise, gives Rotrex superchargers an exceptional competitive edge over any other forced induction solution. The GTM Supercharger kit will Have four different Rotrex compressors to chose from: C38-61 Trim,C38-71 trim, C38-81 trim,C38-91. Combined with our custom compressor housing we will offer two different stages. Stage one up to 500 HP Stage two up to 550 HP All of our Supercharger kits are available in two forms. The tuner kit form, so the professional and the end user have the flexibility of choosing what ever fuel and engine management they may desire and feel comfortable using. The second option being a complete kit including fuel and engine management solutions. With that being said, GTM will also offer an extensive range of fuel system and engine management modules to go with our Supercharger kits. Below is a description of all the components of the kit : -Rotrex C38 supercharger -GTM compressor housing -GTM Supercharger Billet aluminum brackets -GTM billet aluminum Sc pulley -GTM supercharger cooler kit -Rotrex Supercharger Traction fluid -4-Ply High Resistance Nomex Silicon couplers -Stainless Steel T-Bolt clamps -2.5 x 10 x 24 Bar and Plate Core Intercooler Rated @ 700hp -Polished aluminum IC Piping -GTM oil Filter Relocation Kit -Cold Air Intake System (using k&n filters) -Bosch Bypass valve -Pre-made steel braided oil and P.S Supply & Return lines -All Necessary Hardware and Installation Instructions -GTM Custom mapped plug-in And play engine management for optimum engine tune and power . -GTM Basic fuel system with Denso 600cc Injectors and - Walbro 255 Fuel Pump . -GTM Custom Drive belt By Bando -GTM Heavy duty Belt idlers Some Key points about the GTM supercharger kit After literally installing and tuning every supercharger kit available for the VQ platform and seeing their short comings, we got the inspiration to develop a kit superior to all others. Problems with the other kits that we wanted to address with our own include: not supplying a descent amount of power, belt breakage and slippage, obnoxious gear lash noises, limited power expansion and lack of the OEM look. Some of the key things we did to achieve our goal are: SUPERCHARGER NOISE : We chose the Rotrex unit, a very QUIET supercharger compared to anything else on the market . SUPERCHARGER BRACKETS : Our supercharger bracket is 3 dimensional made out of of thick billet aluminum to prevent any flexing, we also mounted the supercharger unit as close as possible to the engine to limit the amount of flex possible, as well as keep the belt length down between pulleys. BELT AND TENSIONER DESIGN : We have over 80% belt wrap on our supercharger's pulley and with utilizing the factory automatic belt tensioner over or under tightening is simply not possible. POWER EXPANSION : Changing the pulley on the super charger is less then 20 mints job AESTHETICS : The GTM Supercharger kit maintain the clean oem look ENGINE MANAGEMENT: With using the GTM flash we are to able to maintain the OEM drive ability so the car will run like stock, only with a lot more power . POWER DELIVERY : The GTM supercharger is best bang for the Buck out of the box Here is the pics of the GTM SUPERCHARGER KIT and some of its major components Attachment 428463 Attachment 428464 Attachment 428465 http://i313.photobucket.com/albums/l...5-03-13-SB.jpg Attachment 428466 http://i313.photobucket.com/albums/l...115-030-99.jpg http://i313.photobucket.com/albums/l.../GTM-030-3.jpg Attachment 428467 Attachment 428468 http://i313.photobucket.com/albums/l...E/P1090920.jpg Attachment 428469 Attachment 428470 Attachment 428471 Attachment 428472 Attachment 428473 Here is the pics of the GTM SUPERCHARGER KIT install process Attachment 428474 Attachment 428475 Attachment 428476 Attachment 428477 Attachment 428478 Attachment 428479 Attachment 428480 Attachment 428481 Attachment 428482 Attachment 428483 Attachment 428484 Attachment 428485 Attachment 428486 http://i313.photobucket.com/albums/l...e/P1120968.jpg Attachment 428487 Attachment 428488 Attachment 428489 Attachment 428490 Attachment 428491 Attachment 428492 Attachment 428493 Attachment 428494 Attachment 428495 Attachment 428496 Attachment 428497 Attachment 428498 Attachment 428499 http://i313.photobucket.com/albums/l...e/P1120945.jpg Attachment 428500 Attachment 428501 Attachment 428502 http://i313.photobucket.com/albums/l...Relaase/19.jpg |
9 Attachment(s)
1 Attachment(s)
The research and development was done on our shop car then we did the first install on the car we are showing here. The car was restored to a 100% stock condition then it was baselined stock so we can measure the exact HP and TQ improvement accurately, as shown the car gained over 140 RWHP AND almost 100 RWTQ by just adding the the super charger system, still on a the stock exhaust and the stock cats . Next we will remove the factory exhaust and test with the an after market one and we will update you with the results.
here is the power output of stage 1 supercharger kit GTM 350ZHR SUPERCHARGER KIT PRELIMINARY TUNING RESULTS. Attachment 428512 |
VIDEO'S OF THE KIT IN ACTION <object width="853" height="505"><param name="movie" value="http://www.youtube.com/v/_gAkrSsGrIE?fs=1&hl=en_US&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/_gAkrSsGrIE?fs=1&hl=en_US&hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="853" height="505"></embed></object> PRICING Pricing as follow Stage 1 Tuner kit $5399.00 http://gtmotorsports.com/product.php...cat=258&page=1 Stage 1 Turn key kit $5999.00 http://gtmotorsports.com/product.php...cat=258&page=1 Sam |
very nice ,looks like it was woth waiting for this
sounds sick
Wow the car sound great:thumbup:
now that my friends is competitive!
Sounds great... time to start saving!
Thats awesome!
Like always Sam, nice job. You HR guy's should be ecstatic.
WOW!!! Definately worth waiting for!!! Wondering if your engine management system works with European models?
soooo C L E A N!!!
Finally! Good job GTM
Originally Posted by TheOtherRob
(Post 8640736)
Quality indeed
Sounds pretty Intense
Wooowwww !
:bowrofl: :thumbup: |
Looks very nice and sounds awesome. Now we HR guys have more options when going FI :icon21:
very nice, other than stage1, aftermarket exhaust and stage 1 dynos, will we see stage 2 dyno? is stage 2 a 10psi pulley or a larger trim supercharger?
