DE to HR upgrade
on
DE to HR upgrade
I have an 04 350 with a blown motor and am thinking about an upgrade to HR. I'm guessing I need the motor, wiring harness and ECU. Not sure about clutch/trans interchange. Has anyone done this swap? How involved is this project?
on
Not a good option for me since I already have a gutted race car with full race cage and all solid suspension bushings ect. Which leads me bach to the question of HR motor swap requirements?
I think you should take this on and create the first HR into a DE thread!!!
General & DIY Moderator
We've detailed this swap in past issues of the defunct Nissan Sport Magazine and can tell you that it is very involved. You'll also need most of the front clip to complete the swap as certain parts, like the starter, are on the opposite side of the engine (which also means the steering rack is different as well). That's not even the hard part: you'll still need to interface with other systems in the car and will need extensive time to re-pin the IPDM. Even after that, expect to have numerous CELs pop up as the wiring harness will have some system checks that lead to nowhere.
It's fine for a racecar, but not so much for a street ride.
I know theres a thread on here where a guy did this swap. He had to pay someone to finish the wiring, pretty sure he had to use the HR dash harness, HR gauges, had to modify the steering column slightly, basically had to swap the entire front clip on the HR and still had to have someone else wire it in. I think Yuri at Wiring Specialties did it.
think about it.... 350z's came which an HR (you should know lol).
exhaust bolts up, intakes bolt up, driveshaft bolts up, shifter bolts up, radiator hoses line up, motor mounts bolt up, etc.
all stock and aftermarket parts for a HR Z would bolt up.
the issues that need resolving is a HR hood and an EMS.
With a HR swap, you could have a mechanically OEM quality setup. With a LS swap, no matter how nice, its going to be a hodgepodge mess of fabrication and welding and rigging through-out. Cool for a drift car or something, not ideal for a driver.
As someone who races a DE-to-HR Z and is intimately familiar with the details (or problems) with such a swap, I speak from experience.
Again, its a bolt-in swap, and the EMS and wiring is the concern. The engine literally bolts into the car. The exhaust literally bolts up. The driveshaft literally bolts up. Everything literally bolts right in, making it a bolt in swap. Everything you need to complete the physical installation is available from the Nissan dealer. There is no cutting and welding. I have not compared the steering racks but I will take your word for it that the relocated starter requires the rack from a HR. So unless you can come up with a list of things you had to fabricate, I stand by it being a bolt-in swap.
By switching to a good standalone like the new Haltech, you will drastically reduce the wiring workload. We have a 350z with the Haltech and everything works perfectly (Except the factory VDC, which is replaced with a more advanced and adjustable traction control system in the Haltech). The car passes emissions too.
You must understand that systems like the Haltech are first and foremost universal systems and capable of running almost any 4 stroke engine created. When you get one that is chassis specific, such as the Haltech, you are even better off... because now it replaces all the secondary functions of the factory ECU, while STILL being able to run pretty much ANY engine. It doesnt matter if its even a VQ at all minus the convenience in that it BOLTS UP to the car. Having a VQ at ALL only aids in making the wiring easier, as its not quite as far off for reusing the existing engine harness and adding some extra wiring to it, as it would perhaps by using an entirely different engine that has almost nothing in a similar location.
As if the LS swap just runs off the stock DE engine management and harness or something! News flash: installing an engine into your car (that is not the engine it came with) is going to require wiring.
Let's get back to the original topic, which asks how complex is this swap? I've said it's not that easy, and you seem to think it is. How many Z owners are going to spring for a Haltech ECM to run their DD? I understand the Haltech (and the AEM and the...), but the point is, not many Z owners are in the position to purchase, install and dial one in. So before we get away from the original topic, let's be clear. The HR swap is not for the guy who has few mechanical skills, or even less money and time to put his DD back on the road. Purchasing a rebuilt DE and having it installed is a much better option for such owners.
I am with you, and I did not mean to come off as that it was so super simple, or belittle the work done by others previously completing the task. I just wanted to imply that when starting from scratch, I feel the HR is a closer match to the chassis than the LS.
I also agree that a built DE is the way to go for the most part. It would take a special scenario to motivate me for the DE-HR conversion.
