HR E85 N/A Setup
Old 07-14-2016, 06:50 AM
  #61
John_B
John_B's Avatar
I got on a Dynocom yesterday for some Dyno E-tunes. There's no issue tuning the car with the new manifold, the only problem was making power lol. I can't really say it made power or not because it was really hot, 93 degrees at 80% humidity. I made 310whp, and there is still a lot of room to tune. My AFR still needs some cleaning, and once that is locked I should see some nice gains. Going to wait later the year when it starts to cool down.
Old 07-14-2016, 06:55 AM
  #62
John_B
John_B's Avatar
As you can see the AFR is still bumpy.
Old 07-14-2016, 07:39 AM
  #63
MyZ32TT
MyZ32TT's Avatar
That's understandable with the weather. How can you describe your mpg with e85 to 91?
Old 07-14-2016, 09:35 AM
  #64
John_B
John_B's Avatar
Switching to E85, i'm around 16.5-17 MPG. Which is about 2-3 mpg difference on 93. 275 till empty from full tank on city. close to 300 on highway.
Old 07-14-2016, 11:22 AM
  #65
HRMoneyPit
HRMoneyPit's Avatar
I want your old mani!
Old 07-15-2016, 06:15 AM
  #66
John_B
John_B's Avatar
It was sold on the next day I posted it .
Old 07-15-2016, 06:33 AM
  #67
HRMoneyPit
HRMoneyPit's Avatar
You only lost 2mpg which amazes me. They always say you loose a ton of milage
Old 07-15-2016, 12:54 PM
  #68
Conway_160
Conway_160's Avatar
10-15% i thought
Old 07-16-2016, 09:01 AM
  #69
John_B
John_B's Avatar
Yea it's not that bad at all. The car definitely eats gas when you get on it all the time. That's where the 10-15% comes in.
Old 07-21-2016, 04:31 PM
  #70
rick1574
rick1574's Avatar
subbed. just saw the gas station next to my job has e85.
Old 07-22-2016, 11:21 AM
  #71
John_B
John_B's Avatar
Just thought of making a list of what is needed to complete this kit.
Must:
- GTR Manifold
- RJM lower conversion
- CJM Fuel lines - contact Charles @ sales@cj-motorsports.com
- 2 Radium fuel dampers FPD-R
- 370z dummy MAP sensor
- (2) -6an Thread to cap the balance tube
- (2) -6an Straight fitting
- (2) -6an Flare Cap
Optional for boosted application:
- (2) -6an to Barb fitting
Add ons: I think these are necessary as well.
- EPS Port matched throttle bodies with the GTR Manifold.
- 3" CAI Moncef intake
Tune:
Z1 Motorsport - Jon Parham
I recommend sending the GTR manifold to EPS Tuning, to have them port matched with the throttle bodies.
::Links::
Manifold:
https://www.facebook.com/rjmllc/?fref=ts
Intake:
http://www.administrationtuning.com/...t-p/hrmaf3.htm
GTR Manifold (port matched) and Throttle bodies:
https://www.facebook.com/epstuningtx/?fref=ts
Plug:
http://www.ebay.com/itm/6-AN-Straigh...zPUyzg&vxp=mtr
Fitting:
http://www.ebay.com/itm/PRE-60615BLK...lUgJ8I&vxp=mtr
Cap:
http://www.ebay.com/sch/i.html?_from...+Blue&_sacat=0
Boost line:
http://www.ebay.com/itm/300953134412?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Hole next to the barb fitting is the missing MAP sensor from the 370z.
The following 3 users liked this post by John_B:
KingBaby (07-25-2016), MyZ32TT (07-25-2016), NA&CH (07-22-2016)
Old 07-24-2016, 11:13 AM
  #72
HRMoneyPit
HRMoneyPit's Avatar
what kept you from doing cams?
BTW i ended up making 292 WHP in 105 degree air temp
Old 07-24-2016, 02:03 PM
  #73
John_B
John_B's Avatar
Cost in general and I didn't just want cams. I would have gone all out.
Nice! The car is tuning out weird at the moment, we couldn't get the AFR right and not making any good numbers. We made 310 on that hot day over here.
Datalog Graph using Virtual Dyno. Between 3800-6200 is where the weird surge and AFR is leaning out. The logs does not show any indication that something is wrong.
Old 07-24-2016, 07:30 PM
  #74
Italianjoe1
Italianjoe1's Avatar
That looks gorgeous, but i'm seeing 5k for 10-15hp? There must be more to it.
Old 07-25-2016, 02:20 AM
  #75
The_Assassin
The_Assassin's Avatar
Hey man, I highly recommend bringing to a shop and have them force relearn the ECU with an diagnostic tool. A Snap-on diagnostic (that looks like a tablet) will work. The shop had a Snap on modis ultra and I was skeptical at first that it won't work but it did!
I know the forums says to use Autel or Consult 3 at the Nissan dealership, but I can confirm that a Snap-On diagnostic will work. Majority of auto shop will have a Snap-On tool. I would call around and ask if they have the diagnostic that looks like a tablet and that you want to idle relearn your car.
Thanks for the suggestion man. I had a shop try to force relearn using a diagnostic tool and it didn't work. The ECU would not accept the changes.
Hey joe, how have you been man. I haven't been to the meets in awhile I am having problems with my z. Willing to pay if you could help me out. Looking to sell it next month.
Old 07-25-2016, 04:17 AM
  #76
KingBaby
Hardest Setting
KingBaby's Avatar
MORE
Old 07-25-2016, 06:56 AM
  #77
John_B
John_B's Avatar
Less than 5k close to 3500. Those results are not the final numbers so it is not looking great at the moment. But, I can definitely say that the car is so much responsive and tourqier than before.
For this N/A setup, the shop guy told me that it is critical to get the AFR dead flat to make any good power. Any dips and surge will rob the power at top end.
Old 07-25-2016, 08:31 PM
  #78
Italianjoe1
For sure tuning is critical on N/A, the a/f needs to be 13:1 all the way out and holding full timing for max torque, even losing 5lb/ft means 10hp up top.
I can appreciate an all-out N/A build but it really is the hard (read: expensive) way to do it.
Old 07-25-2016, 08:32 PM
  #79
Italianjoe1
Let me know, i'm always down to help out. I'm having fun with the benz, getting ready to actually mod it very soon.
Old 07-25-2016, 09:49 PM
  #80
The_Assassin
I changed phones so I don't have your number anymore. I will send you my number via PM so that we can get in contact. That good man. I am sue it will be a beast just like your z
Quick Reply: HR E85 N/A Setup
