Swapping A Nissan 350z De To A Nissan 350z Hr
Old 06-14-2017, 09:15 PM
Santana32
Santana32's Avatar
I got the car to turn on !
Old 06-15-2017, 11:08 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,290 Likes on 894 Posts
...and the dash lit up like a Christmas tree!
Did you even bother to change out the steering rack, core support or radiator!?
Old 06-15-2017, 11:46 AM
travlee
Master
travlee's Avatar
Received 9,045 Likes on 6,511 Posts
Old 06-20-2017, 06:36 PM
08TiburonSE
08TiburonSE's Avatar
Keep up the great work, Mr. Santana.
Old 06-30-2017, 04:58 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Originally Posted by Santana32
Didn't feel like spending 8 to 10 grand on another Z .
Famous last words!
in for this one...
Old 07-21-2017, 05:59 AM
dkmura
dkmura's Avatar
After posting a few pics, it's been five weeks since we've heard anything from the OP. What's the latest on this swap? Or is it dead in the water?
Old 07-21-2017, 08:16 AM
bealljk
bealljk's Avatar
dead in the water assumes it was alive at one time...
d1zguy (08-15-2020)
Old 08-16-2017, 04:50 PM
Santana32
Santana32's Avatar
The Swap been done 100 %
Old 08-16-2017, 05:42 PM
dkmura
dkmura's Avatar
100% as in no CELs, drivability or emissions problems?
Old 08-16-2017, 05:54 PM
Santana32
Santana32's Avatar
Yes sir.
Old 08-16-2017, 07:09 PM
dkmura
dkmura's Avatar
A few details, please.
Old 07-26-2018, 12:47 PM
AceInHole
AceInHole's Avatar
I spent the last year researching and finally accomplishing a similar swap (HR into a G35 coupe), so I felt like bringing this thread back from the dead since I kept stumbling on it while doing searches for it. As a background, I went with the HR because something of a loophole allows me to use that motor in my G35 coupe, which is running in SCCA's ESP class. Due to the class rules, I'm limited to what's available on the G35 (07-08) with limited allowances to modify components for the swap, and was able to get it up and running within the confines of the rules.
Some notes:
- No CEL.
- VDC and ABS work fine.
- HR ECU talks to the DE body and dash through CAN. As a side note: you can load a 350z HR base map onto a G35 HR ECU (which I needed to do since the 07 G35 sedan apparently has a different protocol than the DE Z/G).
- HR starter cleared the DE steering rack. It's close but no issues with it so far. May have to play with things when replacing the starter later but I can live with that since it's not in a terrible spot to access, even with long tube headers.
- DE radiator works with the HR. I used the lower hose from the HR and the upper HR hose didn't quite reach, but the DE lower hose can be cut to work as the HR upper hose.
- Steering controls are activating the UpRev map toggle, but I can't get cruise to "SET". I need to go back over the ASCD wiring.
- Initially had the dreaded "high idle" common on HRs when people clean TBs, but with Nissan Datascan (III) have been getting the Idle Air Volume Learn to stick (fingers crossed).
Car runs and drives great. It's a little odd at first watching the RPMs max out on the tach, but where the DE used to run out of breath the HR keeps pulling.
Rick*K (05-26-2020)
Old 07-29-2018, 09:32 AM
Eli Snipez
Eli Snipez's Avatar
Default hr Dash harness
does anyone know if the hr dash harness will plug in on the de dash
Old 08-04-2018, 12:47 AM
WillieMo_5
WillieMo_5's Avatar
+1^above^
sooo, bare with me for repeating questions or asking silly ones but yes I'm currently swapping an 04 de to an 08 hr (I picked up cheap), since the Nissan mag write up is officially gone and I can't find anymore) I wanted to know if running a haltech platinum with the de ecu (to not have to swap entire body harness) would work ?
Old 08-04-2018, 05:48 AM
Eli Snipez
Eli Snipez's Avatar
Originally Posted by WillieMo_5
+1^above^
it would work but you’d still have to re wire it to work with the engine harness
Old 09-19-2018, 07:37 PM
WillieMo_5
WillieMo_5's Avatar
okay so I've got everything wired in, engine started like a champ on the test drive, dash light up too, but I'm not getting RPMS or mph still... I kept the Fues box from the de engine, if I get the hr, could that be the issue? also I'm having trouble finding where to plug in the bigger size plug from the wire harness, by the passenger side foot area.. any ideas? thats all I have left to have my old girl running perfect again!
Old 12-11-2018, 06:42 AM
Santana32
Santana32's Avatar
Hr swap
Old 12-12-2018, 03:10 AM
  #38
Rick5707
Rick5707's Avatar
Hr swap
Hey check your messages
Old 04-29-2019, 07:14 PM
  #39
Edwing35
Edwing35's Avatar
Default Swap
Some notes:
- No CEL.
. Hey I’m currently thinking of doing this swap myself on my 03 Infiniti g35 coupe. I want the HR engine. Can you please explain everything that was need for you to achieve the full swap?
Old 04-29-2019, 07:31 PM
  #40
bealljk
bealljk's Avatar
I want to see some videos of this!!
Quick Reply: Swapping A Nissan 350z De To A Nissan 350z Hr
