HR rough idle
Old 11-26-2017, 04:07 PM
Gr8tobet8
Gr8tobet8's Avatar
Default HR rough idle
08 HR 90k miles...on start car has really rough idle and dies
throws multiple misfire codes
I’ve cleaned the MAFS and throttle bodies
anyone have any ideas?
Old 11-26-2017, 04:23 PM
travlee
Master
travlee's Avatar
Received 9,044 Likes on 6,510 Posts
Try more basic troubleshooting......what makes the engine run. Air, fuel, spark..... start there, then look to sensors
Atreyu'z 350 (11-27-2017)
Old 11-26-2017, 04:47 PM
Gr8tobet8
Gr8tobet8's Avatar
So far i have
Cleaned MAFS
cleaned throttle bodies
swapped plugs
swapped coil packs
emptied the gas tank and put new fuel in it
O2 sensors are getting the correct voltage
Camshaft sensors also get correct voltage
Old 11-27-2017, 01:44 AM
travlee
Master
travlee's Avatar
What mods, any codes?
Old 11-27-2017, 10:23 AM
Gr8tobet8
Gr8tobet8's Avatar
No mods
p0300 code
im going to clean the fuel system today and see what that does
Old 11-27-2017, 10:28 AM
travlee
Master
travlee's Avatar
did you open the butterflies manually in the throttle bodies?
Old 11-27-2017, 11:07 AM
Gr8tobet8
Gr8tobet8's Avatar
No i didnt
Old 11-27-2017, 11:18 AM
travlee
Master
travlee's Avatar
Originally Posted by Gr8tobet8
No i didnt
good. when you changed the plugs, did you accidentally swap a couple coilpack wires?
Old 12-04-2017, 12:58 PM
Gr8tobet8
Gr8tobet8's Avatar
So since i last Posted i changed The plugs...put a new fuel pump in and new air filters.....
i relearned the idle throttle positions and ECU
the car now runs and idles fine...when i drive it and apply the throttle it bogs down
Old 12-04-2017, 01:02 PM
Gr8tobet8
Gr8tobet8's Avatar
There’s no vacuum leaks as well
Old 12-05-2017, 10:15 AM
Gr8tobet8
Gr8tobet8's Avatar
Default HELP
so i posted on here recently with little help...so let’s try this again
i got in my car one day to drive it and it idled horribly and would die...got to the point where it wouldn’t even start
here’s a list of everything I’ve done
new fuel pump
new plugs
new coil packs
cleaned MAFS
new gas
new air filters
relearned the idle,throttle position, and ECU
So now the car fires and idles right...but when you drive it and the throttle is under load it stumbles on itself...
any suggestions? Cam sensors and CTS are my next purchases
Old 12-05-2017, 10:19 AM
travlee
Master
travlee's Avatar
starting a new thread isnt going to do anything
https://my350z.com/forum/vq35hr/6179...ough-idle.html
Old 12-05-2017, 10:31 AM
Gr8tobet8
Gr8tobet8's Avatar
Maybe your comments should be a little more helpful? If you don’t have a suggestion to the issue shut the **** up and move on
iideadeyeii (12-05-2017)
Old 12-05-2017, 10:32 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
This. ^^^
In the future, please go ahead and just bump your existing thread, especially since it's only a few days old. Dup posts are NOT going to get you answers any quicker than a refreshed original thread and causes confusion. People are busy, you cannot always expect an immediate, right now answer. Thanks.
Old 12-05-2017, 10:36 AM
Gr8tobet8
Gr8tobet8's Avatar
Continous comments with no help....rather than explaining the game that is a forum....maybe....help?
Old 12-05-2017, 10:39 AM
travlee
Master
travlee's Avatar
maybe quit being a little bish and take it to nissan for a proper diagnosis, nobody will be able to diagnose your car from behind a monitor and keyboard
Old 12-05-2017, 10:42 AM
iideadeyeii
iideadeyeii's Avatar
Stop throwing parts at it and diagnose it properly. If you don't have the skills to do so bring it somewhere where they do.
travlee (12-05-2017)
Old 12-05-2017, 11:12 AM
MicVelo's Avatar
Let me explain something here. My responsibility to this forum is to keep it organized and free of clutter. I asked that you not dup post as part of my "job"; and politely I might add by even saying please and thank you in case you didn't notice.
The people that have responded on this thread are always very good sources of information - don't whine when people either don't know the answer or won't attempt a virtual diagnosis without putting hands on it.
If you can't respect that and are expecting instant gratification and results from your posts here, take it somewhere else.
Old 12-05-2017, 11:23 AM
iideadeyeii
He's referring to me. I'm the best
Old 12-05-2017, 11:27 AM
travlee
Master
travlee's Avatar
