3.7 crank in 3.5HR
Old 12-18-2017, 11:19 AM
Xrabbix
Xrabbix's Avatar
Default 3.7 crank in 3.5HR
Anyone able to point me to resources about what exactly is needed to do the 3.7 crank in the 3.5 hr block?
I know the crank drops right in, do I need anything else besides the rods from the 3.7?
Old 12-18-2017, 12:38 PM
Conway_160
Conway_160's Avatar
search my good sir. there is two or three threads about it.
Old 12-19-2017, 03:44 PM
Juztin
Juztin's Avatar
I ran 35HR Block + VHR Crank + VHR Rods + 35HR Pistons on my latest build.
Old 12-20-2017, 02:46 PM
Xrabbix
Xrabbix's Avatar
So is any actual machine work required for this ? (Of the actual rods / crank / block to accommodate the 3.7)
I plan on ordering a new 3.7 crank, and forged hr pistons and vhr rods.
Old 12-20-2017, 06:34 PM
venture210
venture210's Avatar
Dangit Rob haha no additional machine work is needed. Just assemble the HR short as you normally would but with the crank and rods from a 3.7L. Bearing clearances and part numbers are identical. Only the full on stroker kits need clearancing work
Old 12-24-2017, 05:54 PM
HOODEY
HOODEY's Avatar
Compression Ratio?
Old 02-17-2018, 05:50 PM
LOLmustangLOL
LOLmustangLOL's Avatar
you need to run a standalone for these don't you?
Old 02-18-2018, 03:09 AM
Conway_160
Conway_160's Avatar
You shouldn't since your not changing things that much. A stock ECU with Up rev should handle it.
Old 08-05-2018, 06:03 AM
CptWiggles
CptWiggles's Avatar
What is the resulting displacement and what are the pros and cons of this swap?
Old 08-08-2018, 02:05 PM
Conway_160
Conway_160's Avatar
~3.7L. Its a cheap mans stroker kit.
Old 11-03-2018, 09:30 AM
HOODEY
HOODEY's Avatar
What is the resulting compression ratio?
Juztin
VQ37HVR
03-03-2014 01:32 PM
skaterbasist
04-21-2007 07:50 PM
NiSmO21z
03-04-2006 01:38 PM
Quick Reply: 3.7 crank in 3.5HR
