New wheels won't fit... HELP!!!
Guys I just got 17" ASA rims with some winter rubber for my '03 Track, and I can't get the fronts on.
There's a bolt sticking out between the lugs that does not look removable, and it's hitting the inside of the rim. My stock rims do not have this inner ring, so they clear no problem. What do I do? HELP!!!!! :icon43: http://www.darinhamilton.com/images/IMG_0743.JPG http://www.darinhamilton.com/images/IMG_0745.JPG |
The bolt comes out no problem, had to do the same thing on the front of my touring, take the stupid thing out and put your wheels on!
^^^ like said above remove it and no prob, the bolt is on there so you dont try to put you rear wheels on the front.
I found somewhere in my Googling that it's safe to remove... only an alignment bolt. Silly me... ;-)
Go back in to therapy!:icon18:
Be careful, if the bolt is removed the time-space continuim becomes distorted and the world will be destroyed.. .be very carefull
Originally Posted by davidv
I removed those bolts, started the car, and took a trip back in time. Then I met my great great grandfather, and killed him. So now I’m in the 5th dimension because I wasn't born. My question is do I have to file a tax return for 2005? Thanks for your help.
[QUOTE=Havok_RLS2]Nope... Your tax exempt my friend. :D[/QUOTE
Sorry, new tax code rules now apply. You must file as a Non-Represented Ex-Patriate. And since you have had contact with your great-great-grandfather he must now file as a Disembodied, Non-Represented, Non-Resident, Contacted Spirit. You will have to check with the IRS, I beleive there are enhanced taxes for both of these new classifications. |
where in toronto u from :D
Wow you killed off your Paw Paw for tax purposes, you must pay a lotta f$$king taxes.:icon17:
hahahaha:icon17: |
| All times are GMT -8. The time now is 07:31 PM. |
