MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Wheels & Tires (https://my350z.com/forum/wheels-and-tires-60/)
-   -   Why won't my Volk GT-7's fit on my 2005 Base? (https://my350z.com/forum/wheels-and-tires/242951-why-wont-my-volk-gt-7s-fit-on-my-2005-base.html)
iris Jan 14, 2007 03:47 PM
So please help me out: I bought 19" Volk GT-7's in 2003 for my 350z touring (automatic). I put Bridgestone potenza S-04 pole positions on them.
I traded the Touring in in 2005 for a Base (manual) but of course took the wheels off first. I recently tried to put the Volks onto the Base. However, they don't fit b/c there is some additional bolt sticking out of the plate that won't fit into the Volks (the stock rims have a bigger cut out). I only saw this on the front right wheel b/c once that didn't fit, we just gave up.
Volks size:
Front: 19x8.5", +23mm offset
Rear: 19x9.5", + 24mm offset
Tire size:
Front: 245/35R19
Rear: 275/35R19
So am I totally missing the boat on this? Can anybody confirm that GT-7's (at least those made in 2003) don't fit on a 2005? Hopefully it's just an easy fix??
zand02max Jan 14, 2007 03:49 PM
Loosen and remove the bolt with a 10MM socket! Its there to ensure the idiot stealership techs do not rotate the tires!
Then your wheels will fit! Easy Fix! How's the baby coming along?
sam30540 Jan 14, 2007 03:49 PM
You probably didn't know this but the 2005's that have that bolt are factory rejects and should immediately be taken back to nissan for an exchange, hurry or the wheels will fall off if you don't do it quick enough. No really just take a wrench to the bolt and put the wheels back on easy fix.
jcpeyton Jan 14, 2007 03:54 PM
If I've got your description correct, the "bolt" is there simply to prevent mounting stock fronts onto the rears, and vice versa. The bolt is easily removed and serves no other purpose. I had the same question when mounting Enkeis to replace stock. I posted here and got immediate help from members. I'm SURE there is a thread on this because I posted in it. I respectfully suggest you search. Good luck.
zand02max Jan 14, 2007 03:57 PM
Why would she search, the answer has been posted already, lol!
jcpeyton Jan 14, 2007 04:01 PM
Because searching the original thread would have answered the question in the first place. Also, if I remember correctly, there were some funny stories about what various dealerships told owners when asked the purpose for the bolt.
zz350zz Jan 14, 2007 04:07 PM
Since the answer has been posted....I will say the search function sucks.
jcpeyton Jan 14, 2007 04:15 PM
Agreed, the search function in its current form does suck. But, even being a long-term member w/ lots of mods, I've found it helpful (SOMETIMES) at least for narrowing my question. Someone recently suggested a temporary shutdown of "search" for much needed improvements. I agree 100%.
iris Jan 14, 2007 05:23 PM
Thanks everybody. :) I knew it was kind of a stupid question :o but I'm at work and I had to get stuff done wo surfing. Thanks.
The baby is coming along good. 14 weeks (out of 40) and I'm at 118 (gain of 5-6 pounds). Don't know the sex yet. Thanks for asking! :D
DavesZ#3 Jan 14, 2007 05:32 PM
No need to even search, that question is asked and answered in the Top 100 Question... thread, linked from my Sig.
wayneside Jan 15, 2007 12:00 AM
post pics!
