wider stock tires
it is almost time for me to replace my tires on stock 06 rims. i am thinkin of going a little wider and meatier. i know already those of u that will say just get wider rims but it's just not an option at the moment. i want tires that'll hold me over til i can afford rims and to fill the wheel well a little more. please help me out with tire sizes and some pics. thinkin about toyo t1r's or bf goodrich g force. thanks guys for any input and happy new year
What is the width of your '06 rims (18x8" all around)?
I assume the diameter is 18", but not sure what rim width you have. --Spike |
stock tires are 225/45/18 front and 245/45/18 rear
18x8 front and 18x8.5 rear also i think.
Could wind up costing a bit more cause you'd have to get the lugs changed for longer ones to use with the spacers and would likely change back once you buy wheels with a more aggressive offset... I know, not much help, but definitely an option to consider... |
1 Attachment(s)
245/40/18 front
275/40/18 rearAttachment 172646 |
Stock 06 & 07 rims:
F 18" X 8.0" / R 18" X 8.5" F 225/45/18 / R 245/45/18 Queston, would it be ok to run 225 tires on the front and change the rears to 275? |
Originally Posted by gsingh350Z
That looks to be OK, thanks for the picture.
If I wanted wider tires I would get wider wheels.
EDIT: But that's just me.:) |
Stock 06 & 07 rims:
2 Attachment(s)
please search...
Since that question is answered,
Im guessing its totally fine to put an 18x8 in a 245 tire also??? |
^ yes and T1-R side wall is too soft like cream...
what does it mean to have a soft side wall? and thanks guys for all the input.
