MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Wheels & Tires (https://my350z.com/forum/wheels-and-tires-60/)
-   -   What Gives? Can't remove lug nut (https://my350z.com/forum/wheels-and-tires/337036-what-gives-cant-remove-lug-nut.html)
eclipZe Feb 18, 2008 12:58 PM
Trying to mount the rims I bought from Jay'Z today & ran into a problem. First had to get new lugs so the center caps would fit. Axis Mods btw. The ones I bought still too long so I'll get some new ones. Small issue.
Here's what's got me stumped. I can't get one lug nut off the front drivers side. It's turning & turning but won't come off. It's loose like when it gets to the end of the thread but the sucker just won't fall off. Even applying pressure at that lug while turning it does nothing.
I must mention that when I got the car I was getting vibration coming from that wheel. Was gonna take it back to the dealer but discovered it was a loose lug nut. The wheel hasn't been off since I've had the car. Could this be my issue. Something happened when the lug was loose.
Anyway, still don't understand how the lug won't come off. I did have a hard time loosening it. Took many attempts as if I was still trying to break it loose b4 it started to turm
Help!:icon20:
redlude97 Feb 18, 2008 01:00 PM
Sounds like the stud slipped out of the hub
davidv Feb 18, 2008 01:04 PM
The threads on either the lug or nut are stripped. You can turn the nut until you are blue in the face but it is not coming off.
eclipZe Feb 18, 2008 01:10 PM
I was thinking along the same lines. Tried to take a look but couldn't see anything from the back. Didn't get to look very long as I ran outta time b4 having to go to work. Any suggestions?
eclipZe Feb 18, 2008 01:12 PM
I've already done that. Somethings gotta be stripped. Any suggestions on getting it off though?
sry110 Feb 18, 2008 01:12 PM
Can you get a grip on the lug nut to pull it straight out? If your stud is stripped like some have suggested then they will probably just cut the lug nut off, pull the wheel, then replace the stud. Hopefully it's not more involved than that, but it's something you'll probably want a shop to do.
davidv Feb 18, 2008 01:13 PM
If you do not have the tools to crack the nut take it to a pro.
eclipZe Feb 18, 2008 01:19 PM
Well it'll have to be tomorrow as I'm on my way to work. Didn't appear to want to tighten back up when I tried.
eclipZe Feb 18, 2008 08:22 PM
Bump for any other suggestions!
Dave 90TT Feb 18, 2008 08:41 PM
I had the same thing ahppen to me, when I overtightened the lugnuts on my G. Stripped one of them, and broke the stud. Had to drill out the lugnut to get the wheel off, and then had to replace the wheel studs.
Exiled Lakai Feb 19, 2008 05:07 PM
When i was drifting my 240 this was a commen thing because the wheels where going on and coming off so often. You will have to replace the stud and the lug nut. If you have tools and a little skill you don't have to take it to a shop. its fairly easy and stright forward. But if you don't have the time or just don't want to bother with it take to a pro. should take them about 30min tops.
Eazzy Feb 19, 2008 05:14 PM
As said, you stripped the Knurl on the stud. Try this....... Put all nuts back on, You will NEED an impact, impact the stubborn nut TIGHT !!!! Gently heat in for a minute with a butane (expands it) then reverse the impact at full throttle.
I may give you that last chance to grab one more time and spin off
Eazzy Feb 19, 2008 05:17 PM
Keep in mind guys---he has a rim stuck on
eclipZe Feb 22, 2008 10:40 PM
Well finally got 'er off today. I ended up drilling the lug nut & could see through the opening that the lug was spinning but the stud was still. Opened it enough to stick an extension in it & tapped the stud out some & the lug came off. When I had the loose lug nut it caused an indentation around the surface of the stud. So there were threads on both sides of this indentation & the lug would not thread to either side. Pics will clear this up. Anyway, its off & the stud has been replaced. Now I can mount my last wheel tomorrow.
I've gotta figure out how to resize my pics. I post up when that's done.
sry110 Feb 23, 2008 04:52 AM
Good work, looking forward to pics on this one.
eclipZe Feb 24, 2008 07:09 PM
3 Attachment(s)
Here's the stripped stud. After getting it out I know this could have only happened when I had the loose lug nut. Glad I found it this way & not when I was on the side of the road.
