What's the ideal tire/wheel size for a Z?
Hi guys, so I just picked up my 04' Touring, and now I want to get some rims. I was looking at Tirerack.com, but notice that their tire/wheel packages all come with the same size for all 4, and looking at other members here, they keep their back wheels wider than their front, which is what I want.
I want to get 19's, and I was wondering what the favored size and offsets were for 19" wheels. Would 19x10.5 Rear, 19x9.5 Front work? Any information would be greatly appreciated. |
yes, that's it?
umm, no.. don't close the thread. Why close the thread? Isn't the Wheels & Tires forum the correct forum to post a Wheel & Tire question? I'm asking for some ideas, no need to be an arrogant ass. Id like the advantages and drawbacks, and some offset ideas (I'm not too familiar with offsets) |
man... lake george... nice !
the 19x9.5 and 19x10.5 +22 offset 245/35/19 front 275/35/19 rear are the most common setup for a z car. oh and one more thing get rays/volks - or go home. |
thanks for the reply Tac.
When you say +22 offset, that's for both front and rear? Your familiar with Lake George? |
1 Attachment(s)
^ i have been there once or twice. will be back soon for a few days.
yes +22 is for all 4. Chris from http://www.f1motorsports.com/ got me set with mine twice. |
8.5/9.5F
9.5/10.5R 245F 275/285R Between +15 and +20 offset (F & R) |
^^ :+1: Nicely stated... compact (but clear) posting that provides the facts.
--Spike |
I went with the same width all around but different aspects.
275/35 front 275/40 rear, a non staggered setup makes the car handles better. Both are on 18x9.5 +15 enkei rpf1's. In hindsight I would have gone with a slightly less aggressive offset in front so that the edge would be just flush instead of very slightly outside the fender. Back looks perfect though IMO. |
^^ I went with a more conservative setup, keeping the same widths (245 front and rear) but a staggered overall diameter (aspect ratio 40 front on and 45 rear on 18”s) to keep within VDC guidelines. As you point out, the same widths front and rear provide more neutral handling.
Question: Do you experience any “bump steer” with 275’s on the front? --Spike |
^^ Thanks for the reply.
if u want 9.5f 10.5r go with +22 all around thats the most common and for best look the toyo t1r 255/285 if u want a bit more of a stretch on the rear but still looks good just less tire get the 275 on the rear. but 255 toyos on the 9.5" wide rim look perfect.
u gotta keep in mind that some tire brands are wider then others. the t1r's are skinnier width wise then most other tires. and like the michelin ps2's being one of the widest. but were talkin by like 4 mm here. not to crazy |
i had to roll my fenders with advan sports at 275..... totally worth it though :D |
245/35 front
275/35 rear offset +22 all. |
275/35 front 275/40 rear, a non staggered setup makes the car handles better. Both are on 18x9.5 +15 enkei rpf1's. In hindsight I would have gone with a slightly less aggressive offset in front so that the edge would be just flush instead of very slightly outside the fender. Back looks perfect though IMO. I had no idea that non staggered setup meant better, more neutral handling. if that's the case, is there any benefit to going 9.5 f and 10.5 rear other than looks? |
I suppose there might be some setups with suspension power etc that might make a staggered setup appropriate. |
+22 is wimpy offset.
+15 all around for almost close to flush, +/- 2 offset. With 8.5F and 9.5R of course. |
I have 245 on 9.5 +22, it's bit stretched for my taste.
255/35/19 is better choice imo. |
as you can see answers are all over the place and one persons "acceptable" may be total trash to you.
i have 18x9.5 +20 all around. a tad aggressive in the front(+22 would be perfect), and a tad on the conservative side in the rear(+12 or 15 would be perfect). i run 255/40/18 falken rt615's(wide running tire) all around, and will switch to 265/35/18's when these are done. good luck with your search |
What would be the recommended (or common) size for 19s with 12+ offset?
| All times are GMT -8. The time now is 12:43 AM. |
