MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Wheels & Tires (https://my350z.com/forum/wheels-and-tires-60/)
-   -   I have 19's what profile am i supposed to have (https://my350z.com/forum/wheels-and-tires/390532-i-have-19s-what-profile-am-i-supposed-to-have.html)
Chad350z Oct 6, 2008 06:36 PM
3 Attachment(s)
So i know its to late, But i have 19'' Rims, They sent me 35 series tires to go with the rims, is that right? They look a bit to low profile and i hate the extra wheel gap? I dont have to many miles on them, but am thinking of buying new ones? Please help!
sry110 Oct 6, 2008 06:51 PM
Sounds right, but really depends on the widths. Some common 350z fitments would be:
Front: 19x9 with 245/35/19, or 19x9.5 with 255/35/19
Rear: 19x10 with 275/35/19, or 19x10.5 with 285/35/19
M3ANMACHINE Oct 6, 2008 07:25 PM
:worthless:
Spork Oct 6, 2008 08:21 PM
Yes, it depends on the width.
Also, some additional sizes:
Front: 19x8.5 = 245/35/19
Rear: 19x9.5 = 275/35/19
I run Nismo LMGT4's fo the record, and these are Nissan's suggested sizes
lgear080 Oct 6, 2008 08:23 PM
I use 245/275 35 series on my 19x9.5/10.5....
just a thought.
prstriker04 Oct 6, 2008 08:54 PM
i run 245/35 on 10 inch width. but i wanted a stretched look
Chad350z Oct 7, 2008 05:08 AM
Thanks guys for the help i have 8.5 in front 9.5 in rear, and im running teh same type of tires as yall say. so i guess im good. Just looks funny (check out the pics) But thank you so much for the help
Chad
savvy Oct 7, 2008 05:17 AM
just a thought.
same
noodleman Oct 7, 2008 06:03 AM
you just need to lower your car :P
JEFFOS69 Oct 7, 2008 06:22 AM
You can also use a 40 series tires if you want a bit more sidewall
245/40/19 and 275/40/19
These should be a bit taller height wise than the stock wheels 225/45/18 and 245/45/18
When you use a 35 series you should be very close to the stock heights (of wheel).
sry110 Oct 7, 2008 07:11 AM
Jeff hit it on the head, it is important to try to maintain the same overall outer tire diameter as the OEM tires. The wheel/tire is essentially the final gear ratio in your drive train, so variations in tire OD's will cause your speedometer to read the car's linear speed inaccurately, as well as cause your odometer to record miles driven inaccurately.
Anyway if you want to reduce wheel gap either lower the car, or put a fatter tire on there. My previous rear wheels were 19x10 with 275/35/19 tire and I thought there was too much wheel gap (lowered on Hotchkis springs). My new wheels are 19x10.5 with 285/35/19 tires (i.e. taller sidewall than the 275/35's) and to me the wheel gap is noticeably less. Might just be placebo effect because I know the tires are beefier, but I think it actually made a difference.
OffsetZ33 Oct 7, 2008 07:27 AM
Or you can run 30 series if you want less sidewall - but will look funny if you do not have a signifigant drop. I run 265/30 and 275/30.
Concave Oct 7, 2008 07:29 AM
looking at your pictures, the problem may be your offsets.
JS04 Oct 7, 2008 08:03 AM
+1. My fronts are a 245/35. But my rears are 275/30.
Nycraze90 Oct 7, 2008 09:44 PM
if u wanan buy ur new rims ill scoop these off of ya? pm if ur down
Chad350z Oct 8, 2008 02:05 PM
Thanks again, he offset is +35mm front and rear, But your absolutly right i need to lower it!!!
Triple8Sol Oct 8, 2008 06:15 PM
That's right. Your wheelgap is because your car isn't lowered enough. Get on it.
fatboy.yoshi Oct 9, 2008 04:34 AM
and if u decide to lower it more...the wheel fitment will be honda-esque (sunken in) as they are already sunken in now...lower it chunk some 15-25 mil spacers up in there and ur set
Chad350z Oct 9, 2008 01:17 PM
With that Spacer on it will i have to do longer bolts? Yeah im probably going with the eibach prokit and ill throw some spacers on it! Thanks
Bumpinjeep Oct 9, 2008 02:48 PM
35 series is fine. I wouldn't go for 40. All you need is a nice agg. drop and your set.
