Enkei NT03's coming
My Enkei's are in route right now, should be here by the end of the day. 18x9.5+27 and 18x10.5+30, the tire setup I have is Nitto 555's 245/40 and 285/35. What size spacers, if any, would you think would make these wheels sit flush? I was thinking a 15mm rear and 10mm front maybe, I'm not the greatest with offsets, any opinions would be great! Thanks :thumbup:
Sounds like a good setup to me... not sure is 285 would rub
They will only be slightly tucked. I wouldn't recommend spacers. You can fit Michellin PS2 295 in the back easily, even with a drop! ;)
Do you have Brembos? If yes, I believe you'll need at least a 10mm spacer in front to clear.
Originally Posted by Zoom750
(Post 7110720)
First order some real front tires, 245=understeer FTL , lame. Run some 265/35's up front , perfect match for your 285's in the rear. I run a 10mm front spacer with 255/40 and a 20mm rear with 275/40. I would get your tires first, then figure out the spacers you want. If you want , i have pics of my car posted in my profile. |
Originally Posted by Mr.Silvia
(Post 7109894)
They don't clear my brembo's by a credit card. Figuring something out today.
(Post 7114117)
BBKs fit without spacers because they're located further away from the center/hub. |
(Post 7119806)
10mm spacers will do. Not sure about 5mm (I'm doubtful) I used Eibach w/ new studs. Rears should fit with no problems. G/L
BBKs fit without spacers because they're located further away from the center/hub. Figured the way the BBKs are made was the reason for clearance and not for factory Brembos. Will post pics asap, IMO looks awesome. :thumbup: |
still waiting for pics... |
:pic:
You could run +15mm spacers front and rear easy. That puts you right with the RPF1 +15 setup all around (which I'm running).
Be sure to post your pics in the Enkei thread when you get em on! |
| All times are GMT -8. The time now is 11:58 PM. |
