tire set-up
From a performance aspect the Z really needs a 245 or larger front tire. Both the 245/40 255/40 and 245/40 245/45 combo's are ideal for best performance with stock wheels
on
did nissan go with the 225 front 245 rear to keep things understeery and safe? i was looking at tire prices with 615's and 245/40/18 and 255/40/18 seem like the only reasonably priced combo for me. im just worried it will throw off the balance. then again 255 is alot of tire
I ran this exact setup for a long while, and it took some time to get used to. Once I learned the car's limits with the new sizes, everything was fine and my autoX times jumped noticeably.
Former Sponsor
on
615's are not anywhere close to a "track" tire in any sort of skilled run group. If you're a novice, just learning how to feel things out, they will work fine - you won't be permitted to push your car to the point where that tire will be a limiting factor. Focus more on your techniques and following the lines, braking points, etc
615's like heat , and work well for track days, just like any other tire when you get them to hot (overdriving) they get greasy. When greasy they start a nice smooth predictable slide, something some other tires don't do. If you drive them at 100% or lower they are fine, but when you go over, they only require a corner or two to cool down before you start back to 100% again.
You want:
245/40/18
255/40/18
265/40/18 (if you want a beefier rear tire)
Edit: Tire size calculators are your friend:
http://www.1010tires.com/tiresizecalculator.asp
245/40/18
255/40/18
What does "short" mean exactly? In the mean time I'll call him back and see what he has to say.
It means the tire is shorter than stock as noted in post #13
^^Edit, I called the guy and he said just the stockers come up in the database as acceptable tires so he just wanted to make sure i was 100% sure. So I guess it's a good thing but I've never heard someone refer to a tire as "short" before.
The previous owner of my Z has:
225/40/18 front
275/35/18 rear
stock for my touring is:
225/45/18
245/45/18
According to this calculator: http://www.1010tires.com/TireSizeCal...?action=submit He was very wrong. I don't know how long he was running this setup but should I expect damage or inaccuracy with my VDC now?
225/40/18 front
275/35/18 rear
225/45/18
245/45/18
What am I missing?
225/40/18 front
275/35/18 rear
225/45/18
245/45/18
225/40/18 front
275/35/18 rear
225/45/18
245/45/18
I actually have a set of wheels that are:
front:
18x8.5 +25 offset
rear:
18x9.5 +30 offset
In the front I want 235/35-40/18 and a thicker tire with a higher profile in the rear - 265/40-45/18. I know the wheels can handle the tires per this site: http://wheelsmaster.com/rt_specs.jsp
but will my VDC be ok?
My previous stock sizes were:
225/45/18
245/45/18
#38
Just got the new tires put on. Going forward, do I use the same PSI guidelines shown inside the driver's side door, or does the proper PSI level change once different tires are used? I didn't see anything about this on tirerack.
#39
#40
Tonyz_2004_350z
South East Marketplace
10-04-2015 12:53 PM
